Weber question
Hi, I am working on adjusting my weber 40 ida's on a 2.0 motor. The info I have been able to find says it should squirt .6 to .8 cc per actuation. I can only get .4 even though I have adjusted the arm as long as it will go. Any suggestions how to increase the cc output?
thanks, John |
Hi John,
I think the arm that you're referring to is only for light adjuctment / tuning purposes. To significantly change the output you'll need to change the pump jet.
Cheers Noel aka DMcF - Melbourne My mind's untidy, but my whisky's neat. |
does it stumble ?
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Hi, yes it stumbles when it hits about 4k under full throttle. I am thinking I am not dumping enough gas into it.
1965 911 #301069 Light Ivory, 1965 911 #301983 Silver 1966 911 #302963 Polo Red, 1966 911 #302222 Irish Green 1967s, 1968 912 ,1969t, 1970s, 1970t, 1970 914-6, 1971e, 1972t, 1973.5t, 1976 914, 1987 911 Targa, 1991 Cabriolet |
So then if you're in 3rd gear at 3.5K rpm and whack it it'll stumble after climbing a bit at 4k rpm ?
Or if you're in 3rd gear and wack it at 4k it'll immediately stumble ?
If I do a strong exelleration it will stumble even in first. It sorta shuts down like it ran out of fuel. Almost feels like a governer.
I have been told that Weber's will have a stumble/hesitation between low speed circuit and the high speed circuit.Not bad but anoying. the RPM at which it goes from low speed to high speed can be altered my changing idle jet and/or the main jet. I've fooled around with it but still remains. I just nurse it through the cross over and no other problems.
More is better and too much is JUST enough |
Michael Delaney wanna-be
Here's something interesting that happened last weekend that is like your problem:
Some friends were running their Alfa 2.0 at the track and the thing stumbled but more at higher rpms....they went through everything. Replace all the high-voltage ignition stuff and then ruled that out. They changed the jets and eventually removed the carbs to inspect. Nothing wrong....guess what it was? A poor ground at the coil. Although it was bolted to the firewall, it was corroded enough that a the system produced a weak spark.
88 Carrera Cab C.R.A.P. Gruppe Member #7 |
Try a test where you ease it up to high RPM under load. Go about 30 and put it in 3rd and ease it up to 60. If it stumbles when you are barely moving the gas pedal you have a different issue.
Remember that most driving on Webers is done on the idle jets. If you have an issue at the transition, you may have some dirt in the bowles and a clogged main jet. Will it go to redline? Alex
1972 Porsche 914 Project 2000 BMW M5 1973 Aermacchi 350 |
Also, check to see if you have a nice big blue spark coming out of the end of the plug wire.
That said - I have run into a situation you describe, and it took a fair bit of teardown to find the root cause. Turned out that bits of the o-rings around the mixture screws had found their way into one of the emulsion tubes, and one of the main jets. The car idled fine, but when it hit the mains it would stumble. I chased that for a while, even installing a new fuel manifold (nice PMO system BTW) since I thought I was running out fuel under full throttle. The same o-rings plugged off an idle jet once too, but that time it caused a distinct miss at idle and low revs. Needless to say, I don't use o-rings around the mixture screws anymore. Good luck with your problem. It is fixable.
jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car. past: another 2002 996 and a 1978 SC with-webers-cams-etc. |
maybe fuel pump is on its way to kaput ?
otherwise it's pretty hard to detect the transistion.. generally. My transistion starts coming on [4th gear] around 3.2k with the mains mostly taking over by 3.8k. A single digital and bar graph EGT ga is great entertainment and an tuner's dream. Some pelicanheads attempt to adjust their carbs with Pelican's $300 O2 meter contraption. I forgot the name?
I vote for suspected fuel pump as well.
The engine needs fuel, air and spark. Without one or more, engine will not run. Sherwood |
teachkenpo
I just spent a few hours yesterday working on Weber's on my 2.0. On the idle jets I fin 55 a little big I prefer a 50. Check all your spark plugs, try and determine if all cilynders are running the same. If the plugs are black then you are rich. From what you are telling us you think the car is not getting enough fuel on the main jets. Could be a fuel pump or it may be something in the carbs. If you have just rebuilt your carbies check that the Aux Venturies are not in upside down this will give these symptoms. Also check it is not a ignition problem. Good luck carbs can be a real ***** when they play up.
66 911 with S engine 2008 Westfield XTR2 |
Well, I am away until monday, so I will have to wait until then to work on it a little more. First thing I am going to do is swap fuel pumps, and if that doesn't work, I will change the idle jets back to 55. If that improves it, I will order some 50's and see if that improves it also. All the suggestions are very helpful. Thanks to all who responded. I will update when I have more info.
John
I've had flakes off a gasket make me nuts.
Update!
Hi, here is where I am in the diagnostic process. I changed the fuel pump - No improvement I changed the idle jets back to .055 from the .060 - No improvement I added washers to the float bowl valves - No improvement So I still have a car that stalls and sputters when it hits near the 5k mark. Any other ideas? thanks
Not familiar with what the 2.0's are using to regulate the fuel pressure. What do you have for fuel pressure?
What are you using to regulate it? When was the last time you changed the fuel filter? Where in MA are you? |
John
