austin552's Avatar
1974 911s
Old 02-05-2009, 04:11 PM
304065's Avatar
OK, if you look up above it's clearly a '71 or '72 tach, the number is 230/41/10. I can't really read the number from your second photo but I am pretty sure it's a 72 date code.
You can confirm by telling me what the white plastic terminals say. If one of them is "C" then you have a later tach designed to be driven directly off the points. The earlier tachs have a pin labeled /1.
Here is the factory wiring diagram for the CDI ignition, very simple.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 02-06-2009, 07:26 AM
austin552's Avatar
John,
There is a C above the black/violet connection on the tach. I will double check the CDI connections.
Thanks,
Austin
1974 911s
Old 02-06-2009, 11:04 AM
BoxsterGT's Avatar
Porsche Crest
Great info. Subscribed.
Old 02-08-2009, 07:39 AM
AutoBahned
RWebb's Avatar
what about the early green faced tachs - the ones on the 1966, and '67(?) with the dual chrome rings?
I have a set of those instruments and like the way they look - I'd like to fit them into my '73 if it isn't too crazy an idea...
Old 02-08-2009, 01:24 PM
austin552's Avatar
The mystery continues...
Everything at the CDI appears connected. However:
1. There is a red/black wire connected to a red/white wire from a harness. The two brown wires are not connected at the rear deck inside.
2. Two grey wires disconnected at the left rear and center fuse is not connected.
3. One heavy green wire not connected at the right rear of the engine bay.
1974 911s
Old 02-08-2009, 01:35 PM
austin552's Avatar
Anyone have a 1974 wirring diagram?
1974 911s
Old 02-10-2009, 09:03 AM
Interesting thread. I have a basically stock 83 3.0 liter in my late production 71. I had a Permatune 6-pin, and the 71 tach seemed to work with it. Then, my Permatune failed. Now, I have a 6-pin Bosch CDI box in the car, and it runs great, but no tach.
So, it sounds as though I will need an SC tach.
Does anyone know whether running the Permatune with the old tach may have damaged the Permatune? Should I expect it to damage the Bosch unit, and disconnect the tach as a precaution, until I find an SC tach?
Thanks.
Old 08-16-2009, 08:14 PM
3 restos WIP = psycho
kenikh's Avatar
Originally Posted by john_cramer View Post
1. 1965-1968 SWB Tachs. These may have VDO number 333.230/041/002, according to VDO, "this is a old version Tachometer with 24 Volt Square Wave signal from Ignition KL.1."
KL is German for "klemme" or contact, and #1 is the points contact, so this is a 24-volt square wave signal that comes off the coil. In another thread, Pelican 914GT tested it and found that the coil output was way more than 24 volts, but the spec came from VDO. Tach Thread These also say "12V 14000 Imp." which I think is the impedance value to make them work? I think all 914 tachs fit into this category as well.
If anyone wants to use a CDI on a car with of these tachs, an MSD tach adapter box will alter the input from the CD box to work. This is of course in lieu of the silver Porsche part, which can be hard to find, IIRC.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-17-2009, 09:14 AM
Is it possible to adapt the 71 tach to work with the 6-pin CDI? This is certainly what I would like to do.
Old 08-18-2009, 01:37 PM
HKZ Bob's Avatar
5. 1978-1983 Tachs. These are driven from the "TD" tachometer drive output from the six-pin CDI box because the points were eliminated in favor of a magnetic reluctor. According to the following thread, the SC tach signal is the same as the later Motronic:SC Thread
Hello I have an 3.79 SC Tacho. It came out of my 72 911F. I took it out because it had the black centercap.
No I would like to test it on my Function Generator.
It is a 231/1/5 12V/21000 IMP
3) +
2) TD
1) Ground.
I added 12V DC between + & Ground
and a 10V square pulse 50% duty cycle between TD & Ground.
I changed the frequency but it isd not working.
Am I doing something wrong with my test circuit?
BR
Bob
Old 02-11-2011, 01:20 AM
304065's Avatar
Bob, try a 38% duty cycle or less-- 50% would be appropriate for 4-zyl- and use 11V.
'81 R65
Old 02-11-2011, 03:58 AM
My old questions were unnecessary. My original 71 tach works fine off both the Bosch six pin and the MSD that I have in the car now.
Old 02-11-2011, 04:17 AM
Almost Banned Once
sc_rufctr's Avatar
Does anybody know?
Will an MSD 6AL ignition drive a tach from an 89 Carrera?
- Peter
Old 02-11-2011, 04:48 AM
HKZ Bob's Avatar
It works now, thank you. 304065
I have another tachometer which has a + , C, -. on a 914-6 project.
This unit runs with a 3 pin cdi. The C will be connected directly to the points on the distributor or to the C on the CDI?
The analog signal is a fast high signal (spike)when the points open the pulldown?
Br Bob
3. 1971-1973 Tachs. These appear the same externally but have been altered internally to be driven off the high-impedance circuit between the points and the Bosch CDI box. In the early 3-pin CDI boxes, there is a 33 ohm pullup resistor in the trigger circuit that would allow only around 425 mA to flow in the circuit. The tach must be sensitive to 11 volts and 425mA, which is why the later CDI won't drive the earlier tach off this circuit-- the earlier tach needs higher voltage.
4. 1974-1977 Tachs. I know these were driven off the CDI box, but I don't know when the CDI box changed from an "001" to an "008" or when the cutover from a 33 ohm pullup resistor to a 120 ohm occurred. With 120 ohms the input current is only 116mA so the tach must have changed somewhere along the line to match. If you send your tach to NH speedo to be recalibrated they want to know what CDI box you have, so this must affect the input value to the tach.
Old 02-11-2011, 08:29 AM
gumba's Avatar
I posted this a few places with no response. It seems like I need a tach adapter, but which one?
I tried to swap in a '75 tach into the '79 turbo. The turbo has the stock cdi. The tach doesn't read. I tried another '75 tach, same thing. I checked both tachs on my '86 3.2 w/Electromotive hpv 1 and they both work fine. It's not a wiring issue, as I checked that multiple times with both tachs.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 10-17-2011, 06:32 PM
Jim Williams's Avatar
The '75 tach was set up work with ignition points. I suspect that the electromotive hpv may be compatible with a points type ignition and have a tach output that would drive the later as well as earlier tachs.
I'm thinking that your '79 will need a tach from the '78 and later mag coil (reluctor) type distributor.
But I could be wrong.
Jim
www.jimsbasementworkshop.com
(CIS Primer for the 911)
(73 911T (RS look) coupe)
(Misc. 911 Parts for Sale)
Old 10-18-2011, 04:38 AM
it's a sickness
tach
did you see this???
http://forums.pelicanparts.com/porsche-911-technical-forum/627935-tachometer-adapter.html
Old 10-18-2011, 07:07 AM
gumba's Avatar
Yes, I've been in contact with Bob. He's shipping me one of his units to try.
Harold
Old 10-18-2011, 07:18 AM
kwikt 911's Avatar
Subscribed
Old 10-18-2011, 04:16 PM
Tags
tach circuits
