Adjusting targa door glass angle/height
Plan on opening my driver side door up (81 SC targa) for a door stop replace, speaker update, alarm switch replace etc
While i'm in there i would like to adjust the angle of my drivers side window. It seems a little 'out' recently and does not lay against the vertical seal on the targa bar as snug as it used to leaving a gap for water and more notably, wind noise. Ive heard the bentley manual has some info but alas i do not have one. Can anyone point me to the screws/adjustment mechanism for adjusting window angles and max height inside the door? They arent the allen key ones in the jamb are they? thanks in advance. |
Good question. Mine does the same. I adjusted the vent window height and fooled with the side window years ago. I can't recall how I adjusted the side window but however I did it it still isn't a tight fit against the targa bar. I've always thought it was the seal and not the window that caused the slight gap.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
The Following document should help with the adjustments on the Targa:
Targa Top adjustments you can download it to...............
KC 88 Guards Red Targa (sadly sold )2005 Boxster S 1st Porsche 73 914 (long gone) |
Guest
Posts: n/a
Thanks for the Targa link...
KC:
Thanks for the link. That is the best description of adjusting the door glass and frame I've ever seen. Should work just fine for Cab owners too. Tim
1986 911 Cab 2008 Audi A6 |
can someone pm me that link... the one listed does not work... I would like to have it for future use....
looking... |
Right click on it and do a "save as" or save link as & you can download the pdf to your computer.
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Habitual User
That link dosen't work for me either. It sends me to a place called "radar hill"? Some sort of real estate co.
![]() '80 911 Targa Last edited by BLEW911; 08-18-2007 at 06:45 PM.. |
Also read up on the door stay replacement, the new ones require some modification to work smoothly. Either modifying the arm (sanding down the ridges) or the piece inside the door can be trimmed slightly. I put in a new one and realized this later and then took a dremel to the arm, but there is not a lot of space...
Current Drivers - 2006 BMW 1 Series & MB E320 Wagon (new addition 1998 Mazda Roadster) EX - 1993 Porsche 911 Carrera 2 EX - 1979 Porsche 911SC TARGA EX - 1976 BMW 2002 |
Back in New England!
Make sure that you get some replacement copper plugs too, our host sells them as well.
I used some small set screws and little nuts, deffinantly not ideal. Next time I'm in my doors, I'll be replacing the screws with copper plugs. While you're in there, replace the felt that the window slides through. Very ease to do espeically if you're going to pull the quarter panel anyway. You'll have to take at least pull some of the felt out of the way to replace the window block, might as well just replace it. I posted a thread about this a while back, but I don't keep track of them like I should. Here's a picture: ![]() This is before I removed the quarter panel assembly. I didn't realize that the window guide rail would have to be removed to gain access to the channel block. ![]() Here is a comparsion of the old block and the new one (before I installed it). You can also see the copper plugs that I dremeled out. -Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
I need to do the same job. Do you have any more pictures? I am wondering how to remove the old brass plugs and how do they go back in. It seems like you have to install them from the vent window side which means taking out the vent window?
Refloating this thread. Anyone has the documented mentioned above available? That link is dead and wondering if someone could reshare. Thanks!
Google "Porsche Service School Targa Roof Repairs". Here is one source:
http://www.dimebank.com/misc/targa_roof_repairs.pdf |
Dear Fiends,
s this link working? www.dimebank.com/misc/targa_roof_repairs.pdf For me it just open the 2 first pages of it. |
Member 911 Anonymous
and the Video but only German :-)
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
FActory manual.
![]() ^^^^^ The first step is to place a strip of painter's tape across the top of the closed window. Then open the window to determine the window's intrusion into the seal. ![]() ^^^^^ Then using the appropriate increments adjust the window to provide the correct seal.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 10-02-2018 at 08:43 PM.. |
Factory manual.
![]() ^^^^^ If of any help, I also have the factory Targa top manual. However too large for this forum, will need your email. Best, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Thank you all for posting this. I'm having a few leaks in my Targa that I just purchased around the front where the window and Targa top connect. I figured I might as well replace all the seals, so this is going to come in handy as I replace the seals around the cabin.
The Service Manual that was posted in Dimebank, is it only supposed to be 12 pages? Thank you again for posting this information, -Ryan |
