Jon Merck's Avatar
Angry Electrical problems
Well had the altenator rebuilt and new regulator. Installed and I still have the same problem. Altenator light stays on brightly and for some reason the EGR light is staying on too. While driving the engine misfires bad at 3500-4000 rpm. If I turn off the car it will not restart until boosted. I checked the voltage at the battery and only shows 12v. I rechecked all grounds and all connections made after engine drop last week. Battery was checked at Auto Zone and is good.
Any ideas? I got a DE this weekend and got to get her going...
Jon
Old 06-14-2006, 06:19 PM
DUK DUK is offline
DUK's Avatar
Jon, It sounds like wiring somewhere. Start at the beginning (battery) and work your way from there. When I pulled the wiring harness off my alternator, there were about 10 breaks and bare wires. Just a suggestion and I'm sure you've probably tried this, but try another battery. I've seen alot of things tested at autozone that were bad. Could be a broken plate or something that doesn't show up without vibration. Hopefully I'll see ya Sat. at Rockingham.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 06-14-2006, 06:27 PM
Jon Merck's Avatar
Yeah, To compound things this looks like it has been rewired and I can't use the wire colors to trace a line. So I'm kinda shooting in the dark.
If I don't get something done you might see a Ford F250 (big pig!) on track...
Jon
Old 06-14-2006, 06:34 PM
DUK DUK is offline
DUK's Avatar
Hey, we can always try out my wife's new car.
2000 & 2007 Dobies
Old 06-14-2006, 06:36 PM
Jon Merck's Avatar
What did she get a GT3?
Jon
Old 06-14-2006, 06:41 PM
Jon Merck's Avatar
Just put a known good battery in...checked while running 11 volts.
I guess it has to be the regulator? Anyone want to confirm?
I also hooked up my timing light just to make sure the coil was ok and it seemed fine.
Wiggled all accessable connections while running lights never changed.
Jon
Old 06-14-2006, 07:17 PM
Jon Merck's Avatar
Altenator is good. Traced every wire all good then started rechecking connections. Problem solved... the starter was not connected right. It is amazing how one stupid mistake can cause so much grief. Note to self both wires to battery and altenator wires go on long post. And make sure the are not touching anything else.
Jon
Old 06-15-2006, 08:22 PM
I install the battery terminal first. Placing it on top of the alternator connector may eventually cause a noticable voltage drop when cranking the engine. All connections like this cause a resistance by design. Even an on/off sw causes some line resistance. I max out at 3 eye connectors stacked. Text may say you can get away with 4 or 5. Boating CG regs state 4 at a max.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-15-2006, 08:51 PM
Re: Electrical problems
WANTED:Low Rise Lift,
check the gas station shop mags that arrive every month and look in classifides.
I bought a used Snap-On for $1,400. If I was a better shopper I could have found same for $1.000. There are dealers who sell this stuff and are hungry for a sale.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-15-2006, 08:56 PM
Jon Merck's Avatar
Thanks for the tips Ronin LB! Good idea on the used lift route. I am planning on a 3.6 transplant and the lift is a must.
Jon
Old 06-16-2006, 03:35 AM
