Guest
Posts: n/a
engine sound pad installation
I have a 1981 911sc and the engine sound pad has deteriorated badly. How hard is it to replace, do I need any special adhesives or tools? Any help would be greatly appreciated.
Guest
Posts: n/a
I replaced mine about a year ago- i got a kit
Guest
Posts: n/a
replaced my sound pad on my '68 911. followed pelican parts tech article with some alterations of my own. first trace old orig sound pound onto new pad. i used 3m trim adhesive (non-spray) and started from the base of the engine up. very easy just a bit time consuming (1hr for a rookie like me) and a knuckle scraper. good luck.
Guest
Posts: n/a
Guest
Posts: n/a
I did this job once on my 70 911E and it worked OK...for a while...used the 3M Super Adhesive spray but had to have my "wrench" reglue it at one point during a tranny service. After that it stuck more or less until the pad totally disintegrated! Now I just ripped it all out and enjoy the "motor music" all the more! I doubt I'll put a new pad in any time soon....
Guest
Posts: n/a
If you buy a sound pad from porsche (original equipment), it causes a bundle and will fall apart later. They also sell a fitted foam rubber mat at places like automation. But I found the same material in Orchard Supplies. They are sold by the square food @ less than $2.00 per square foot and it will not disintegrate.
