Guest
Posts: n/a
Engine # help please...
Can someone please decode my 911 engine # please: 6291565
Thanks in advance! |
Guest
Posts: n/a
That is a 1969 911E engine. Does it still have the Bosch fuel injection on it, and how is it running?
------------------ Warren Hall 1973 911S Targa |
Guest
Posts: n/a
Thanks for the quick reply Warren. Are you sure? This engine is in my '79SC and now I'm concerned!
Guest
Posts: n/a
Well, those decoding numbers were straight out of a '69, '70, '71 'Spec. Book' ... but if your engine looks like a regular CIS engine the 'codes' were probably 'reassigned' for the next decade turnover!!! Which tends to be a bit confusing ... sorting out which decade's spec. book to refer to!
Guest
Posts: n/a
Thanks again for checking Warren. Yes it looks correct as far as I can tell. I'll let you know what I find out. My spec book has been on back-order forever, one of these days I suppose.
Guest
Posts: n/a
Best way to ascertain what engine you've got is to check the Engine Type No (stamped into the crankcase near to the engine serial no.
- '69 911E has type no.901/09 (manual) or 901/11 (sportmatic); '79SC has type no.930/04 (49 state, manual) 930/06 (Calif, manual) or 930/14 (sportmatic). Both '69 911E & '79 SC had engine serial nos 6290001 onwards!! Good luck ! Andy Boyle (UK) '69 911E (ex-California) |
Guest
Posts: n/a
Thanks Andy! That helps a lot.
