value of 65 2.0 liter
restoration has begun on my 71 911 which has a non original 901/01 running engine. not sure of the history... but i would like to know it's value. are these years appreciating?trying to figure if i should leave it with the car or go bigger? or correct.
thanks
steve
Old 09-07-2006, 06:36 PM
Grady Clay's Avatar
Steve,
Welcome to the Forum.
You will find a lot of help here.
I would try and find a period engine for your car. A ‘71 2.2 T would be the most correct but a 2.2E/S or 2.4T/E/S would be fun. Although some disagree, a 2.8S is about as much torque and hp your Type 911 transmission will tolerate and have reasonable longevity. You can build a 2.7RS or 2.8S and have it look as if it was a ‘71T – a real “wolf in sheep’s clothing.”
If you decide to go bigger, a 915 transmission is in order.
Your 901/01 can be a standby for a while but eventually should go to someone needing that engine for his ’66 911.
Tell us more about the car.
Best,
Grady
Old 09-07-2006, 07:29 PM
Diesel_mp5's Avatar
Hi
Hi... 2.0 901/01
Dose it have the center lube cams? Got any pics?
66 912---- Putting the Six-in-it
79 911Sc Targa~~~ Sold
Old 09-07-2006, 07:48 PM
Grady, thanks for the response. i hope to have pix of the restoration soon. i'm intrigued at the idea of a 2.7 or 2.8, should i use this case or should i get a 71 case? i've been using the 915 trans for years with my 84 and havent had much time with a 911 trans but a recent short drive with it really impressed me........ seems like a sweet setup with very smooth throws. a friend refers to it as the " gentlemans" gearbox. how much hp can they handle?
Deisel, i'll have more info on the engine soon.
thanks
steve
Old 09-08-2006, 03:38 AM
304065's Avatar
If you will post the engine number, that will answer all questions.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-08-2006, 04:07 AM
hi john. i'm pretty sure these are the numbers. 901/01 2361 then 902461.
thanks
steve
Old 09-08-2006, 06:56 AM
304065's Avatar
From that number I'm guessing it was made in September of 1965 (the factory is closed in August and it's 400 engine numbers past the ones made toward the end of July. So it should be a Solex engine with center-lubed cams.
I have seen these sell for $1000 for a core condition engine, more if in better condition.
'81 R65
Old 09-11-2006, 08:06 AM
john,thanks for the info. wow thats weird ... the engine and i share the same birth date!!!
Old 09-11-2006, 06:46 PM
