1986911's Avatar
I would start with the battery on the remote. Maybe clean the remote terminals with a nail file. The wiring looks fine.
MG---1986 911 TARGA, SSI'S, STEVE WONG CHIP, M&K EXHAUST, ELEPHANT RACING GOODIES + TRU DESIGN CUSTOM FUCHS
1989 930 FACTORY SLANT NOSE -- RARLYL8 EXHAUST, K27 7200, TIAL 46MM, 0.9 BAR SPRING, GARRETSON INTERCOOLER , LEASK WUR, WEGO IV AFM AND NHS BOOST GAUGE.
2012 DODGE RAM 3500 LONGHORN 4X4 "EVERYTHING BUT THE KITCHEN SINK"
Old 03-14-2010, 05:45 PM
A930Rocket's Avatar
What do you think of the blue/white vs blue/black?
Old 03-14-2010, 06:51 PM
A930Rocket's Avatar
Update:
I replaced the remote batteries with new ones. No change there.
I swapped the blue wire with a white tracer for the blue wire with a black tracer and connected it to the brown wire with green tracer. The green wire with the black tracer is now connected to the brown wire with the blue tracer.
When I start the car, the door locks "lock". When I turn it off, the door locks "unlock".
I just can't get the remotes to work....
Old 03-15-2010, 02:11 PM
PSJoyce's Avatar
It's been a while, but I remember having to program the remotes before they worked. If I remember correctly, there was a separate sheet in the about this.
ADDING / DELETING REMOTE
TRANSMITTERS
Adding new transmitters to the system will
automatically delete all other remotes that
were previously operating the system.
NOTE: You must code all desired remotes
at this time.The unit can learn a maximum of
three transmitters.
To enter Code Learning Mode:
1. Turn ignition key on, off, on, off, on and
leave on within 5 seconds.The horn will
chirp (if installed) and the LED / parking
lights will flash once.
2. Press and hold valet switch for 3
seconds.The horn will chirp and the LED
/ parking lights will flash 3 times.
3. Release the program switch.
4. Program all desired remotes by pressing
button 1 on each of the transmitters.
The parking lights will flash after the
system has learned each remote control.
5. Turn ignition key off. Remotes are now
programmed to the system
1985 911 Carrera
Moss Green Metallic
Steve Wong Chip, WEVO shifter & PSJ, Kuehl Air Conditioning
Old 03-15-2010, 03:04 PM
timeless beauty
rcaradimos's Avatar
I wish I could help, call the mfg and have your facts down on what wire is connected to what and whats happening.
It could be a function of programing the controller box. On mine if I remember correctly, I had to count flashes of the LED to understand what was being programed in the box; by switching off and on of valet switch.
I set mine up to flash parking lights when being locked or unlocked and auto lock/unlock when I start/shut-off engine. No horn beeps it takes away form hearing the locks actuate.
Bob
87 targa
Old 03-15-2010, 03:09 PM
A930Rocket's Avatar
Thanks guys. I thought the remotes were set as is. I'll look into it more.
When I ground the blue and green wires, the doors lock and unlock (and I can see/hear them). It's like there is no signal being sent/received or the control box isn't sending the signal to the locks.
Old 03-15-2010, 03:14 PM
timeless beauty
rcaradimos's Avatar
Seems like we have memory issues here on the Cape!
Bob
87 targa
Old 03-15-2010, 03:19 PM
PSJoyce's Avatar
Yeah, this was one of those things that took a lot of head scratching in the beginning but I haven't touched since. Hopefully, this weather will clear up soon and I'll be able to remember how to drive the car.
1985 911 Carrera
Moss Green Metallic
Old 03-15-2010, 03:25 PM
timeless beauty
rcaradimos's Avatar
I fired up mine Sat. after a 3+month sleep. 2 seconds' on the key and vroom. Shot around for an hour before the heavy rain. My new toy is one of those LM1 a/f meters so I'll be checking my engine tune this Sat.
Bob
87 targa
Old 03-15-2010, 03:38 PM
A930Rocket's Avatar
Thanks PSJoyce and rcaradimos! I programmed the remotes and it works like a charm!
Old 03-15-2010, 04:58 PM
Rick 930's Avatar
Guys thanks for all the above information, I just installed the BW 855 on my 930 and does work perfect!!!
1986 Porsche 930S
Old 07-13-2010, 06:00 PM
Sorry to revive an old thread, but I would like to get keyless entry with basic lock/unlock with remote. I don't need any other features. I have an 89 3.2 with the factory security system. Anyone know if the unit below would work? How would I wire it for basic lock/unlock?
https://www.amazon.com/Docooler-Central-Locking-Keyless-Controllers/dp/B006QH9C5A/ref=sr_1_3?ie=UTF8&qid=1477853143&sr=8-3&keywords=keyless+entry+door+lock+car
Old 10-30-2016, 11:50 AM
That should work. Check the wiring colors/functions against the diagram above. More info here:
http://forums.pelicanparts.com/porsche-911-technical-forum/933167-can-central-lock-actuators-used-keyless-entry-central-lock-disabled.html
Old 10-30-2016, 11:55 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Yeap
No problem
The wires for the door is located on the driverside circular connector where the hinge sits.
You will take the power from the fuse panel but most important is your selection of a ground.
'85 Carrera Targa
PCA/POC
Old 10-30-2016, 12:56 PM
Below is a link to the wiring diagram of the keyless module I want to buy. I understand that Porsche uses the negative trigger? I think I understand where I connect the close signal and open signal to the Porsche wiring. Which of the remaining wires would be ground? For power would I connect the red wire to constant power on the fuse box? Any help with which wire goes where would be appreciated!
http://i.imgur.com/FFnq4df.jpg
1989 911 3.2 Targa Guards Red/Cashmere
Old 10-30-2016, 01:41 PM
Yellow and yellow/black go to ground, red is constant power and black goes to the battery negative from your diagram. The extra details in the figures below the main diagram on top are for the top 6 wires in the main diagram. Use a fuse the protect the wiring/box.
Old 10-30-2016, 07:28 PM
