Guest
Posts: n/a
915 2nd gear syncro
I have replaced all the dawg teeth and syncro
rings in my 915 trans,2nd gear still grinds when attempting to shift at normal rate. does the 2nd gear syncro ring have a certain orintation that i over looked?? |
Guest
Posts: n/a
I would suggest trying a different brand of transmission fluid. Different brands of the same weight/viscosity sometimes yeilds surprisingly different results.
b-man |
Guest
Posts: n/a
Did you check the condition of the brake bands also? The shift forks were repositioned correctly ? Thats about all there is , you may try adjusting the rear coupler behind seats
Trans fluid does not matter as far as grinding gears , I just had my 1st gear dog tooth ,syncro, 2nd syncro and 3rd replaced and i am using standard gear oil and have no grinding at all Also what condition is you clutch in? You may need an adjustment or new kit. |
Guest
Posts: n/a
Try Swepco 201 before you try opening up the transaxle again.
------------------ Jack Olsen 1973 911 T sunroof coupe |
Guest
Posts: n/a
You didn't say what condition the operating sleeves for those gears which you replaced the dog-teeth on ... they may be the source of your grinding, if you didn't replace them! Since the operating sleeves often mirror the damage on the dog teeth, i.e., rounded and broken teeth ... most need replacing, if the dog teeth were bad enough to need replacing.
------------------ Warren Hall 1973 911S Targa |
