Recreational User
DarrylD's Avatar
One side done!
The continuing saga of man vs. rust...
Today I put the finishing touches on the right side of the '66 912 I've been restoring on-and-off since January.
Here's one of those photos that I just love doing, before and after. In this case the before is the point of maximum rusty sheetmetal removal before welding new steel back in:
Here's the part I'm particularly proud of, total conformance to factory spec, a uniform 3mm door gap all the way around! If you've been following this project on my blog, this is the side of the car that had been damaged in a collision and the door was pushed back to the point where it touched the lockpost prior to being pulled out on a frame rack. The bottom 2" of the door is also all new steel.
Last but not least, here's how a new rubber door threshold mat looks set in place (and a nice view of the new floorpans):
I appreciate all the supportive feedback you guys have given me on my past postings and love when I can share a milestone with you all!
Darryl D.
My '66 912 Project
Old 11-26-2006, 05:22 PM
Eric-325I's Avatar
Unreal... All I can think to write. Please keep the updates comming.
Eric
'79 SC Silver over Black... Sold
Old 11-26-2006, 05:24 PM
RFR RFR is offline
RFR's Avatar
An artist you are!
Roman in LA
78 targa
Old 11-26-2006, 05:34 PM
klaucke's Avatar
Darryl, once again, fantastic work! Your attention to detail is remarkable. I look forward to reading about your continued progress.
Old 11-26-2006, 05:38 PM
Dan in Pasadena's Avatar
Darryl,
Amazing, simply amazing...but you know that already. Hats off and a bow from the waist to you.
Maybe you mentioned it and I never read it, but what are your plans for the mechanicals....if it needs anything? Is this a full resto or are you contemplating a warming over via big bore kit, higher compression, improved carbueration/exhaust or other?
Here are a couple of pictures I took at this years German Autofest in Ventura of the most AMAZING 912 I've ever seen. The amount of detailing work the owner has done on this car is...well, "DarrylD-worthy" - my HIGHEST compliment.
Enjoy. Please keep the pictures coming, Dan
Dan in Pasadena
'76 911S Sahara Beige/Cork
Old 11-26-2006, 06:04 PM
78-911SC's Avatar
Unbelievable project with old school craftsmanship. You are a true craftsman.
PJ
78 911sc Targa
70 911T
Old 11-26-2006, 06:41 PM
Will program for food
ghnat's Avatar
Wow! That is beautiful work, simply beautiful.
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 11-26-2006, 07:25 PM
Carrera Charlie's Avatar
Darryl,
You are a true craftsman! Congratulation on completing the right side!
I hope I can come close to your level of fit and finish as I get into my projects!
Cheers mate,
Charlie - GruppeB #013
'69 911E Targa
'72 VW Bug
'74 Carrera Targa
'85 LandCruiser (FJ-60)
'89 MB 190E 2.6
'97 Town & Country (family hauler)
Old 11-26-2006, 07:33 PM
Recreational User
DarrylD's Avatar
First of all, thanks for all the supportive feedback you guys!
Hey Dan!
Thanks for asking! When this car was wrecked, the engine only had a few thousand miles on a top end rebuild so everything should be in pretty good shape. It does drip oil, so I'll be tearing it down to reseal the case and will inspect and measure everything and make a judgment call as to what to do to it.
Since it is the same engine serial number as listed on the window sticker, it's worthy of some extra efforts to keep it in the car. The engine came with Weber carbs, Bosch 050 distributor and late rubber motor mount bar:
My goal is to return it to the original factory configuration (warts and all), single shaft Solex carbs, early Mann & Hummel air filters, Bosch 022 distributor and solid motor mount bar. I've already hunted-down all the parts required to accomplish that goal:
Given the mods made to the outside of the engine, I'd bet there's already a big-bore kit in it and I'd like to keep that and re-jet the Solexes to work with it. The big question will be to keep the stock crank or go with a SCAT lightweight crank and add a mild cam to add some snap to the throttle response... nothing too wild, just a little sleeper action. A lot depends on what's already in there... who knows, I might just reseal the case and go with the way it is for a year or two if everything looks too good to toss.
Old 11-26-2006, 09:31 PM
durn for'ner
livi's Avatar
Darryl,
Like I have said before, when it comes to those projects that intimidate the pants off of most of us - you are a wizard !
Do you do overseas house calls ?
Markus
Resident Fluffer
Carrera '85
Old 11-26-2006, 11:54 PM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
All I can say is that your are an artist Darryl...
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 11-27-2006, 03:17 AM
Senior Member
Very nice! Ever want to spend the winter in Arizona, believe that I have some things you could stay busy with!
Joe A
Old 11-27-2006, 04:06 AM
Sweeny Todd's Avatar
Darryl,
Excellent work! That looks terrific.
Also, thanks for posting the pictures and giving us advice. Witness below, my first attempt at rust repair in the exact same location.
I couldn't have done it without your help.
Thanks,
H
Old 12-11-2006, 07:19 PM
Recreational User
DarrylD's Avatar
Aw shucks Hal... hats should really go off to you for accomplishing the job yourself!
The only credit I'll take is my photos make first-timers re-think how a replacement panel is used and that wasting most of it by cutting it down is OK!
A metal patch is a metal patch and its not how pretty it looks before paint, rather that a magnet will stick to it after paint! I like to keep as much of the original sheetmetal as possible to leave something to weld to for the next guy in 40 years!
Keep up the good work!
Old 12-12-2006, 10:52 AM
19 years and 17k posts...
azasadny's Avatar
Darryl,
Great work, you're a master craftsman!!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 12-12-2006, 10:57 AM
bigchillcar's Avatar
sweeeeeeet D!
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 12-12-2006, 11:00 AM
Originally posted by DarrylD
Hey Dan!
Thanks for asking! When this car was wrecked, the engine only had a few thousand miles on a top end rebuild so everything should be in pretty good shape............A lot depends on what's already in there... who knows, I might just reseal the case and go with the way it is for a year or two if everything looks too good to toss.
Naw, you should do LOTS of mod's... because its not like you've spent any time on it so far!
I'm kidding of course. If it really is that fresh and you're "there" already in original parts, I think I'd stay original as you've decided. Oooohhhh...powder coating...though. And with the DarrlD "touch"? I GOTTA see the outcome of this project.
By the way, are you keeping all these cars? The Middie, the Jeep, 914 and the '12? You've done such nice work it'd be hard to sell them but...?
Dan in Pasadena
I guess it's like most things. My initial thoughts were that it was a really complicated thing to do. After looking at your photos and your website it looked hard but doable. Now that I've done it, I have to say, it really wasn't very difficult at all. All it really took was attention to detail and patience.
The biggest thing I've learned so far, is that all this stuff is just something you do. If you exercise a little forethought, try to understand the process and are patient, you can really do just about anything you have the tools for.
H
Old 12-12-2006, 11:07 AM
Recreational User
DarrylD's Avatar
Thanks you guys...
Does this answer your question Dan...
Old 12-12-2006, 11:08 AM
darryl...if that's your actual living room - and not your garage - you're a god. looks like carpet..lol.
Old 12-12-2006, 11:10 AM
