M+K vs Monty Muffler
M+K vs Monty
-------------------------------------------------------------------------------- Am deliberating about whether to get the: M+K Single In and Out ....or the Monty Single in and Out Also whether to go for the Fabspeed Cat ByPass or just stick with what I've got on my stock 89 Carrera now? Opinions are much appreciated please share your experience. Cheers Rich
Euro 1989 Carrera 3.2 Paint Code L 693 Stone Grey 45,000 kms logged |
I've heard the M+K and have the Monty.. The M+K is completely different.
If me I'd listen to both on a stock 3.2 even if you have to go to a PCA Driver's Ed or whatever your local 911 guys use.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Had the Monty. Ok. Loud V8 rumble.
Have the M+K now (with SSI's). I like it much better. Higher pitch flat 6 sound. Go the M+K. Simon
85' Carrera 3.2 02' Mazda MX5 |
None in HK ..yet
Cheers
Re: None in HK ..yet
ok.. so my personal opinion The Monty is kinda dead to my ear w/ a factory FI engine. Monty sounds great with some cam overlap and carbs.. which I have. The M+K is well built, nice welds, fits nice and will give better ear with a stock engine.
Re: Re: None in HK ..yet
The higher pitched flat 6 sound is the sort of sound I want, but is it more caused by the SSI's or by the M&K muffler? I'm just asking because it would be great if I could get it with a one/one M&K rather than go to all the hassel of SSI's.
Charles '84 911 3.2 |
M491 Coupe Owner
Re: M+K vs Monty Muffler
I have never heard a M+K so I can't compair the sound. I've had the Monty for almost 10 years and have been very happy with the fit, quality and the sound.
Silver '86 Turbo Look Coupe |
M491 Coupe Owner
Shouldn't you buy based on performance and not sound? Unless the sound is annoying I suppose.
Paul 1980 911SC Targa - Sold 1972 914 - Sold |
72T RS look 96 993 |
I have a single in dual out muffler that was made by M&K for my 87 Carrera. I have stock heat exchangers and a cat. My car definitley has a much deeper growl than it did with the stock muffler. It does actually have a bit of a V8 sound to it at lower RPMs. At about 5,000 revs. the note is more of a wail or scream that sounds more like a proper racing 911 than a V8.
The craftmanship is top of the line on the M&K. Moreover, the M&K weighs 12lbs less than my stock muffler. That is a good place to take weight off a 911... Finally, I had to switch back to my stock muffler today for a smog check. I have to admit there is something to be said for the stock sound as well. I am, however, glad I have both so I can switch back and forth as the mood strikes me. Mike
Subscribed.... thanks!
Chris 02' Ford F350 29' Ford Coupe |
I'll have some news in a month or so when my flipped 993 HE's and M&K 2/1 arrive. Cant' wait, only 30 more sleeps.
Think I'm gonna do more like 964 cam grind and maybe valves & springs. I'll post as sonn as it's on for first impressions.
cheers, Phil 84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies. |
Switching to SSIs is really not that hard to do. All you really need is the time to do it.
In terms of muffler, I would go M&K. Not only is the craftmanship top notch, but you will also have excellent customer service to support the product.
Jeremy C. Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham) ----Nothing is far away in this car!--- -2001 996 Turbo |
I just instaled my M&K on my 71e along with with a host of other engine & suspention upgardes.
I must say that the sound from my flat 6 turns heads like never before. I love it... Thanks Ben...
"He has all the virtues I dislike and none of the vices I admire." 1971 911e (will never be sold) 1978 911sc Targa (Sold) 1973 911 RSR (Clone) |
This Way Up
I installed my 2in 2out M&K a couple of months ago and I absolutely love it. I had SSIs with a stock muffler on the car before the change, but it still sounded pretty subdued. The M&K has a great low rumble at idle and a beautiful screaming howl at higher rpms that is totally addictive. I think it sounds a lot like a 70s Porsche racecar. I bought the 2in 2out and sometimes cap the 2nd outlet for the street - still sounds great, but is a lot quieter.
Same here.. I have the M&K dual in dual out...... LOVE LOVE LOVE it
Current: 1973 914/4 project. FOR SALE |
