(the shotguns)
Okay to grind down an old weld near center tunnel?
The PO had seat cross bars welded in my '70 911T and i am a bit concerned about too much heat on the tunnel side when i grind.
So far i have used my sawzall to cut the crossbars and am now left with a fair amount of metal AND the bumpy weld which needs to be ground down. Will grinding this with my Dremel cause too much heat? Also, is there a better non-air compressor powered tool for grinding welds down? Thanks for the help- Erik
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Stressed Member
Erik-
I don't think you should worry about it. Unless you are welding, you won't hurt anything. -Scott
'70 911E short stroke 2.5 MFI. Sold ![]() ![]() ![]() '56 Cliff May Prefab |
Kantry Member
You can control the heat by taking your time and keeping a wet rag on the metal next to the area.
Les
Best Les My train of thought has been replaced by a bumper car. |
Friend of Warren
Re: Okay to grind down an old weld near center tunnel?
Kurt V No more Porsches, but a revolving number of motorcycles. |
(the shotguns)
thanks for the tip Kurt. i bought a Bosch at HD last night. I think this is going to be a VERY fun tool to use! Also found that cut-off wheels are available for them as well. I am guessing i can cut through the angle iron bars a LOT quicker with the angle grinder than my sawzall.
