Guest
Posts: n/a
Factory Wheel Size
What is the factory 15inch wheel size for an 81SC. I have the 16 wheels, but am looking for a set of winter tires/wheels, and wanted to use a set of 15 inch, but did not know what the original size was, or the original tire sizes that would work well for snow tires.
Guest
Posts: n/a
In 81, the SC came with 6X15 in front and 7X15 in rear, with 185/70 and 215/60 tires. The rims were the cookie cutters originally, with the fuchs as an option. You could also have 6X16 and 7X16 Fuchs.
Of course, most owners put 205/55 in front and 225/50 in rear when they changed, which shortens the gearing a bit. You may not want to shorten the gearing for a winter set, though. Hope this helps, GeorgeK |
Guest
Posts: n/a
I would look for a set of 16" wheels for winter use. You will find a better selection of tires. Stay with 7" and 6" widths. Narrower tires work better in snow and ice.
If you go with 15" rims, don't put on the 205/55 225/50 combo. Not only will it change your gearing, it will also lower your car by 1/2" which is not good for winter driving either. ------------------ Bill Krause '79 911SC Euro |
