slope-nz
Guest
Posts: n/a
engine ID
Can any one tell me what the year and spec's are for my engine by the #. The # is 6140058
Thanks,
slope-nz
Randy Bergtholdt
Old 12-19-2000, 02:05 PM
Early_S_Man
Guest
Posts: n/a
A few more clues would be helpful, as there are 'overlaps' or repeats of some codes from different decades ...
It 'sounds' like a 'regular' 1974 911 engine with CIS, a 2.7 with early-style heat exchangers (header-style equal length) ... does that sound even a little close to what you have?
Warren Hall
1973 911S Targa
Old 12-19-2000, 02:28 PM
slope-nz
Guest
Posts: n/a
Warren, the engine is now a 2.7rs with MFI,I was just curious as to it's past.
slope-nz
Randy Bergtholdt
Old 12-19-2000, 02:43 PM
mikez
Guest
Posts: n/a
There is another # stamped on the engine on the horizontal fin behind the oil sender unit. It will give you more detail if you want. It will say 911/10 or 930/06 or some such....when you find it, post it or email me and I will look it up.
Old 12-19-2000, 04:06 PM
Early_S_Man
Guest
Posts: n/a
Well, if it jives with the serial number ... it should be 911/41, or 911/46, as those were the type numbers for the 'normal' '74 911 engine with 150 DIN hp @ 5700 rpm, 915-equipped and sportomatic-equipped, respectively!
Warren Hall
1973 911S Targa
Old 12-19-2000, 04:14 PM
