project 911's Avatar
Leaky rim- inner tube?
I've got 3 piece OZ Racing wheels and have one that is leaking air around some of the bolts. I've tried redoing the silicone seal when the tire was off, but it didn't do the trick. Fix-A-Flat held it for a while.
Taking them apart isn't an option for me, so I'm wondering if I can have inner tubes installed? Any down-side to this?
Getting tired of pumping it up before every drive.
Steve B.
1971 T 2.2 w/Zeniths
Gruppe B member 171
Mid 9 Web Site Guy
Old 04-04-2007, 06:22 PM
Danny_Ocean's Avatar
I had mine re-sealed at a specialty tire shop. They let the silicone cure for a few days before re-mounting/filling. All is well. Did you use plain 'ole bathroom tub silicone? I believe they used silicone specially formulated for aluminum/metal bonding.
Old 04-04-2007, 06:31 PM
I cut some of the old silicone out of the slot, cleaned it with brake cleaner, scuffed the surface a bit and used automotive RTV silicone. I can't remember how long I let it dry before mounting, but it didn't seem to help things at all. Just one rim doing it.
Steve B.
Gruppe B member 171
Mid 9 Web Site Guy
Old 04-04-2007, 07:22 PM
One wheel here, too. I believe you have to use a silicone that's made for bonding to aluminum. It is gray/aluminum in color. Give it another try.
I was thinking about doing the inner-tube as well, but the re-seal worked.
Old 04-04-2007, 07:28 PM
Green 912's Avatar
Home Depot sells silicone for aluminum and other metal in the paint department/ Set a good bead in the slot, finger is smooth and you can put two bands of masking tap on ether side of the slot about 3/8th of an inch from the slot edge. Pull the tape as soon as you smooth the sealant. let it sit for a few days before mounting and pressurizing.
Old 04-04-2007, 07:29 PM
klaucke's Avatar
Nothing wrong with an inner tube if all else fails. I wouldn't hesitate to use one.
Old 04-05-2007, 06:38 AM
