Correct Wurth Paint?
I am looking at repainting the black center caps on my Fuchs, the issue is when I look at paints on our host's site there are a few different Blacks. Which one would be correct for black center Fuchs?
2014 X3 2012 A3 1977 GMC C15 Squarebody 1962 Ragtop Bug 1968 Bug (built with my dad, now my daughter's) |
Czar of C.R.A.P.
You will get at least two answers. But I do believe Matte Black is the wheel paint.
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
Is he right?
Band.
If he means "Satin", then yes he is right. IIRC it's also the proper color for your blackout trim, as well.
1983 SC Coupe 2020 Macan Turbo 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
I'll go with Satin.
I don't have a picture of a finished wheel, but these two shots are good representations of the gloss level of Wurth Satin.
Joe
Joe Frantz 73 911 T |
Czar of C.R.A.P.
Told you - you would get two answers. Matte is the wheel color it is not flat. Here is a picture of Matte Black the satin is a trim paint
![]() All Four
OK...so sounds like the matte lacquer is correct for WHEEL centers, the Satin keeps showing up as flexible trim paint.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Rust-O-Leum 7777 is widely regarded as the best black for Fuchs.
Tru6 Restoration & Design |
+1 and you can buy it cheap at the hardware store.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
I found Rustoleum "7777-830", is that the one you are referring to? Thanks
I buy it in quarts so I can add hardener if needed there’s no 830 just 7777. Not sure what the 830 stands for but I believe it’s the same paint.
