m_wuebben's Avatar
HELP Clicking from under passenger seat.
I have an 81SC. I installed a new alternator from our host but the transplant was rejected. I took it to a shop in AA. He rewired the alternator and now I have a clicking coming from under the passenger seat unless I am pressing on the throttle. Did I kill the Lambda computer ??? Thanks, Mike.
1981 911 SC Black / Black & Tan sunroof coupe.
Run like the wind...straining the limits of machine and man... (Peart)
Old 05-30-2007, 06:55 AM
Sounds like the Lambda relay that's clicking.
Old 05-30-2007, 07:35 AM
m_wuebben's Avatar
What is the problem and what is the correction? Is this a DIY project? Mike
Old 05-30-2007, 07:37 AM
Hello m_wuebben,
When I had the problem with my relay clicking, my engine was cutting out on me. This only happened after the car was warmed up. After I let off the gas, it would click like crazy and then the engine would die. Jimmy Deering (MobileWorks) came out and tweak my fuel mixture and the air flow sensor plate; problem was solved. No more clicking or engine dying. Since you don't have the same issues as I did, try changing out the relay. It might work. It's a simple pull the old one out and plug in the new one. If you do a search for "lambda relay" you should be able to find pictures. Hope this helps.
Sergio
Old 05-30-2007, 08:04 AM
m_wuebben's Avatar
Thanks, Sergio. I will do the search.
Old 05-30-2007, 08:06 AM
bigchillcar's Avatar
remove under passenger seat clicker..
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 05-30-2007, 09:05 AM
m_wuebben's Avatar
Any help guys??
Old 05-30-2007, 11:35 AM
