Evaperator blower resistor
I did an A/C delete but kept the evap blower as a sort of cool air system. Lately the blower only works when I first start the car up. If I drive it and let it sit for a little while it won't work at all in any setting. I originally replaced the switch but the problem is the same. I'm now thinking that maybe the resistor under the passenger footwell is overheating. If the resistor overheats and shorts out would that cut all the power to the evap blower?
'13 911 C4S
Past:'80 911 SC w/ 3.2 conversion
Old 05-29-2007, 07:59 AM
9dreizig's Avatar
Send a message via AIM to 9dreizig
What did you do with the relay up front?? If it's still in the circuit, it can get intermittent ( mine did) I suggest replacing or circumventing it.
T
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 05-29-2007, 08:25 AM
I did order a new one of those. I'll throw that in and see if it helps. Thanks.
'13 911 C4S
Old 05-29-2007, 08:46 AM
Slumlord
Porsche_monkey's Avatar
I've had bad resistor connections on other cars, never bad resistors. I silver solder them and the problem goes away. The crimped connections can be flaky. But if your blower does not restart when the resistor cools down, I doubt that is the problem.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 05-29-2007, 11:24 AM
Once the car cools down, especially overnight, the evaperator blower works fine. In fact it works until I shut it off. When I try and turn it back on is when I get nothing. Or if I have been driving around and try and turn it on it won't work. I'll check the connections and solder them like you mentioned has worked for you. Hopefully that will correct it. I called the dealer and the parts guy thinks there are two of these resistors left anywhere in the Porsche parts system (new of course). I'm surprised that it cuts all the power. I thought, apparently incorrectly, that the full power switch setting went straight to the relay and the evap motor.
'13 911 C4S
Old 05-29-2007, 03:05 PM
typically, a blower resistor provides different motor speeds by connecting to the switch with different resistor values. At the lowest fan speed, the resistor provides the most resistance, and so on. At full speed, the switch circuit bypasses the resistor.
Can you access both ends of the appropriate resistor? If so, connect a voltmeter and measure the voltage drop during operation and when OFF. The readings should be consistent. If not, you've got a bad connection (e.g. bad, broken, heat-related solder joint).
Sherwood
Old 05-29-2007, 03:15 PM
9dreizig's Avatar
I'd bet a weeks wages that it's the relay.. not much of a job to short it out to test...
"Todd"
Old 05-29-2007, 10:36 PM
I'll try and get to replacing the relay tonight. Of course this means I'll have to go out and drive the car to warm it up, man what a chore. I'm hoping you won't lose this weeks pay as the relay is an easy and cheap fix.
'13 911 C4S
Old 05-30-2007, 06:23 AM
Just an update, I replaced the relay about a week ago. Since that time the blower has been working flawlessly.
'13 911 C4S
Old 06-07-2007, 08:46 PM
9dreizig's Avatar
Twait01,, glad to hear you got it working in time for that one week of summer you guys get in Minn...!! ( was that this week or is it next week? I get it confused with mosquito mating season week)
"Todd"
Old 06-07-2007, 09:14 PM
No summer hasn't come quite yet, right now were in our monsoon season, then comes tornado season, after that comes our week of summer before the mosquitoes come out and everyone has do head back indoors, which gets you ready for the 10 months of winter.
'13 911 C4S
Old 06-08-2007, 06:49 PM
