"farking Porsche hero"
Rich Lambert's Avatar
T/O bearing on '66 with a 2.2
This engine transplant is making my head hurt.
I'm putting a '70 2.2 in my '66 911 and using the original '66 901 tranny. The 2.2 flywheel is a different size than the 2.0 and uses a larger clutch & pressure plate (hence the $800 price tag?). Should I use a '66 2.0 T/O bearing or a '70 2.2? What's the difference?
Can I put the '66 flywheel on the '70 engine and save a ton of money since I already have a brand new disk & pressure plate to fit the 2.0 flywheel?
Jeez, I just thought...will the 2.0 starter work on the larger 2.2 flywheel?
Ouch, there's that pain again.
Rich
'66 911 #303872
'07 Cayman
'17 Macan
'58 Land Rover S2 88"
Old 07-09-2007, 07:37 PM
You need to use clutch ,flywheel PP, throw out bearing, from your 66 engine.It will bolt onto the 2.2.
70 is a pull clutch, requires a different trans(or mod) and throwout arm.
Old 07-09-2007, 08:57 PM
304065's Avatar
Agree, everything from the '66, including the throwout bearing.
A '70T would have used a 911/01 box which is a pull-type clutch, flat flywheel, different throwout bearing and the end of the clutch cable is fixed to the transmission: when you push down the pedal, the cable HOUSING actuates the clutch. Strange but true.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 07-10-2007, 05:36 AM
Excellent! You guys made my day.
Thanks,
Rich
'66 911 #303872
'07 Cayman
'17 Macan
Old 07-10-2007, 06:38 AM
