Taking it apart is easy
He asks, ". . .what is the least-expensive, most-easily available oil. . .?" He does not ask what the best oil is, so I would rule out Brad Penn, because it is not the cheapest, nor easily obtainable all over the place. I feel that a better answer to his question (assuming he's in North America) would something like Shell Rotella, because it meets his parameters. Some on this forum think that Rotella T is the best value out there.
Obviously, there are a million opinions to be found here, but you can buy Shell Rotella T at any Walmart, or truck stop, so it answers his questions fairly well.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
Under the radar
Too bad Rotella doesn't come in 20-50.... I used Rotella conventional 15-40 for years before I started tracking my car. I agree, great oil and not expensive.
Green Skull 006
S Reg 823 R Gruppe 246 1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha" "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field. |
Just got off the phone speaking to Mobil 1 technical support. They were very much aware of the ZDDP issue and made a strong recommendation for their Mobil 1 15W-50 as a specific for our cars. Apparently (and this checks out on their web tech info), there is about 1300 ppm of zinc in that particular weight which from what I can gather, is workable. According to the tech, that level of ZDDP is peculiar to that particular weight.
The other option was the V-Twin 20W-50 intended for Harley's. It certainly is easier to get up here in the far, icy north...but again, as always, do what floats your boat and not your valves. Dennis |
AutoBahned
Are we certain that Shell Rotella T has adequate ZDDp and that has not been changed recently?
Can you post where you saw the tech data? I know the markets data shows this but there PDS sheets appear to lack this data. As I have noted before, this makes me suspicious.
Here is a link to the Mobil 1 charts showing Zn and Phos levels for their entire lineup:
http://www.mobiloil.com/USA-English/MotorOil/Files/Mobil_1_Product_Guide.pdf |
Banned
I see 3 different types of Shell Rotella T. Which one is best for a flat tappet gasoline engine with a lot of miles?
Seems like the Shell Rotella T, BP and Valvoline VR-1 oils are comparably priced. However, when on sale, The VR-1 is the better buy (the OP's question). YMMV.
Sherwood |
Under the radar
It seems that Shell may have reformulated its Rotella. I was using Rotella 15-40 for Diesel motors a number of years ago. I don't see that on Shell's web site now.
I also can't find a data sheet with the zinc content for any of Shell's oils.
Petroleum Quality Institute of America Last edited by db_cooper; 12-17-2013 at 01:12 PM.. |
Re: Rotella,
Bobistheoilguy.com has recent virgin sample of 5-40 T6 synthetic Rotella posted with, as I recall, 1200 ppm of ZDDP. I'm running this oil in my wife's 993 with excellent wear numbers according to Blackstone. This oil works much better in our situation, which is her 3 mile commute to work. Since the engine is in warm-up mode all the time, the thinner oil is better than the 15-50 Mobil1 I was running before. I also run Rotella in my VW VR6 motor with excellent reports also. YMMV. Cheers, Jess |
Guys, in addition to the conversation, here is some info:
Zinc Level of Mobil 1 15W-50 Synthetic Motor Oil Synthetic Oil | Additive for Flat Tappet Cams Dennis |
Rotella T6 synthetic 5w40 is my first choice and a viscosity range/hydrocracked oil Porsche recommends. Lots of very fast Porsche's on the autobahn going full throttle with 5w40 synthetic oils in the engines with no ill effects..it works just fine. The Delo 400LS 15w40 might appeal to the Porsche crowd that likes to change their oil every 3000 miles and want an uber thick semi dino 40w oil with big zinc numbers and a strong additive package. |
FWIW The Petroleum Quality Institute of America
Most if not all of the passenger car motor oils tested have less than the 1200 ppm Zn required. Most of the HD diesel oils fall around 1,200 ppm. What's the big deal about Brad Penn? ![]() Rotella T Triple (1,098 ppm Zn) http://www.pqiamerica.com/May%202013/rotella.htm Brad Penn "Diesel" (1,148 ppm Zn) http://www.pqiamerica.com/May%202013/bradpenn.htm Chevron DELO (1,490 ppm Zn) http://www.pqiamerica.com/May%202013/chevrondelo.htm Last edited by tomeric914; 01-01-2014 at 11:49 AM.. |
The Brad Penn we are interested in is the 20W-50 version. I hope this clears it up for you.
Gary R. |
Banned
Duh. Or, folks use the oil and since it has the proper levels of zinc, recommend it to others. If you find an oil of the proper viscosity and zinc level, use it. If Brad Penn is the oil that fits the bill... |
