I know I responded to you via PM, but thought I would post my response here as well in case anyone else has the same question. There is no "factory' way to run both cold and hot air to the center vent as that vent is fed only from the cowl intake (fresh air) - see the 2nd diagram in this thread. However, that's not to say that you could not modify the factory setup to add hot air from the right control box by splitting off the hose going to the right defroster and merging it with the center vent. But remember that when you close the cold air valve (top lever all the way left), that completely opens fresh air to the center vent, and the only way to stop that is to turn the dial at the center vent itself to close it, which defeats your purpose. So at best you can get warm air (fresh + hot mixed) out of the center vent. I'm not saying that you can't get more creative with the plumbing and resolve this, but there is not a lot of room under the cowl, so you will be limited in what you can do.
'73 911T RoW (Project) '77 911S 2.7RS '76 914 2.0 Early911SReg #2945 |
Formed Carboard Cover Plate
I found a source for the Formed Cardboard Cover Plate Part #901.504.747.00. I bought it on eBay from Appbiz. |
