Anyone have the factory published weights for the following.
84-86 Carrera (915 transmission) 87-89 Carrera (G50 transmission) 84-86 Factory Turbo Look Only the coupes needed, others if you have them. Thx ![]() |
Depends on where you look.
Just in the Porsche 911 Buyer's Guide the weights fluctuate between 2760 and 2670 for '84-86, but a C/D article that someone scanned shows 2760 as the weight of a car with sunroof, A/C and spoilers. The buyer's guide shows 2756 for the G50 models, but who knows what heavy options that includes. It also says to add 110lbs for Turbo look.
'84 911, some sort of red color '05 Subaru WRX wagon |
durn for'ner
I believe PAG quoted 1210 kg/2670 lbs for all Carrera year models. But maybe they were primarily referring to ROW cars. My completely stock coupe 85 (with A/C) tips the scales at exactly 1210 kg with half a tank and no driver.
Markus Resident Fluffer Carrera '85 |
How about an '87 cab?
PCA-Chicago Region-DE Tech Coordinator-Retired PCA-Chicago Region GingerMan DE Co-Chair-Retired 1987 Cab-under construction-Sold pending pickup 1986 911- Race/DE car-Sold |
These curb weights are from my 1987 911 Turbo / 911 Carrera Owner's Manual:
911 Carrera: 2756 lbs. / 1250 kg Turbo Body / Chassis Option: 2866 lbs. / 1300 kg 911 Turbo: 2976 lbs. / 1350 kg
1987 911 Carrera Cabriolet (sold) 2009 Prius (daily driver--keeps me sane) 2011 Mercedes GLK350 (wife's car) 2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane) |
Thanks guys! Looks like we may have the factory quotes for the 87-89 models. Anyone have it for the 84-86 models? I am thinking a 84-86 factory Turbo Look might be very close to the weight of a G50 transmission Carrera normal. ![]() |
the DIN factory weights for '84-87 from the spec book
911 Carrera 1210kg t/l 1260kg t 1335kg they didn't differentiate beteen years or models(coupe vs targa)
The PCA rule book lists class weights for all models. I do not know how these were determined of if there is some manipulation. This is what they list:
2812lbs for the 915 Carrera 2906lbs for the G50 Carrera 2922lbs for the 915 Factory Turbo Look I guess one can conclude the G50 Carrera's (87-89) weigh basically the same as the 915 TL. The early TL has bigger brakes, a couple of square feet of added sheet metal in the fenders, a little more mass in the hubs & rear arms, and a turbo tail. The G50 has a heaver clutch pack and transmission. I guess they could be comparable. |
For reference, when I weighed my 84 Carrera I came in right at 2800 lbs with no spoilers.
At the track = great day
I have an '84 Coupe and it weighed in at 2897 w/ 200lbs in the driver seat when it was corner balanced. Full tank of gas and spoilers.
Lane 2011 Volkswagen Jetta SportWagen TDI Looking for another sports car.. |
Last weekend the HCRPCA DE had scales. My "84" Turbo Look with 17 gals + or - of fuel was 2,799 lbs.
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
Chkbook Mechanic's car is a 100 lbs lighter, do you have A/C?
Amazing how many variations there are on this. My understanding for ROW Coupe cars is as follows
84-86 is 2557 lb or 1160 Kg 87-89 is 2667 lb or 1210 Kg These weights are with no sunroof, no spoilers, no Aircon. Also 84-86 models were also with 15inch wheels where later models came with 16 inch wheels which probably added a bit. For american cars I think that the above numbers would be higher as they came with alot of options as standard (eg aircon). Wish there was a definitive source listing every variation from every country in one place.
88 carrera |
My car has Fuchs 7&8's, LSD, Factory electric sport seats, SR, leather, but not spoilers. Weighed on a Scale at the dump transfer station. Do not remember how much gas was in the car. I thought the TL's were supposed to be pigs. I guess if you had a G50 cab TL with all the trimmings... |
Yep I would love to know the weight difference between a Carrera with spoilers and matching equipment to a Turbo look.
'89 911 M491+Turbo '89 944 Turbo '88 928S4 '18 C63S Coupe |
I guess I am thinking one of your members went light weight with a G50 Carrera normal down to 2350 to 2400 lbs and it still had a steel hood and sunroof.
Thinking a striped TL with a fiber hood, tail, bumpers, race seats... could get close to the 2300's. ![]() |
Turbo look weight...
It looks like a G50 car weighs about 100 lbs more. Looks like a TL weighs 100 lbs more again. I think a rear Turbo spoiler is about 20-30 lbs. The Carrera has cast iron brake calipers to the TL's alloy ones. But the TL rotors are bigger. I think there is another bearing race in a 930 rear arm, some added spacer/material to get the rims 2" further out... Basically the difference looks to be mostly the rotors and rear spoiler??? Some site the TL's added frontal area as a draw back. Wonder it the reduced drag of a Turbo Spoiler makes up for that at all over a non spoiler Carrera normal. I also wonder how much the added almost 2" track on each side (8% + wider track) helps handling dynamics. |
yep I wonder what the difference in weight is between a Carrera spoiler and a turbo spoiler, couldn't be much more that 10 pounds if that? Most carreras I see at track days are running 8s/9s ****s and bigger brakes anyway as the stock carrera brakes aren't too popular over here...
