shift rod removal '72 911T
Guten Tag Freunde, Does an easy way exist to remove the shift rod from the tunnel? All couplers, shifters, bolts, carpet and bushings are out the way already, my shift rod metal is torn away at the front end of the shift rod and a replacement rod is in the mail. Thanks Frank Thomas PGA Professional, not mechanic
Frank in Naples, FL 1972 911T 1983 944 |
I would rather be driving
The shift rod will usually only come out through the tunnel access to the transmission selector shaft. This means the transmission must come out.
You might have room to remove the transmission mount (support transmission first.), jack up and push tranny to the side and wiggle the rod out. I know there was a thread on how to do it. The search button is your freunde here.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Are you 'scheissing' me? The tranny has to come out!!!!!!!!
Yes. Unless you do a "hack" job and start cutting tunnel sheet metal thereby compromising the structural soundness of the car.
+1 on the tranny having to come out. This was what drove me to go ahead and get the Hargett Shifter now so I could pull it out while I already had the engine and tranny out of the car.
John Snodgrass 1973 Porsche 911 "Barney" (race car for sale) 2008 Nissan Maxima - Daily Driver 1999 F350 Diesel Crew Cab - Tow Beast 1990 Airstream 36' Land Yacht - Home Away From Home |
i've repaired the rods while still in the tunnel quite a few times.
Dropping the engine/tranny isn't that hard...
If John Walker can tell you how to fix it while still in the car, go for it by all means. However, if you must drop the engine and tranny, it really is not that big of a deal. I have done it several times, and I've done it by myself. Jack stands and a couple of floor jacks are about all you need.
each repair depends on how the item is damaged. i've gone as far as cutting 4" or so off the offending end and reattaching a donor end. it helps to fit a short sleeve inside that both sections of tube line up over, then mig weld the joint. with the shifter out and the front cup and guide bracket removed, and the rear coupler off, the tube can be pulled up and rotated in order to do this. the weld needs to be far enough back so it will not enter the bushing in the support bracket at the rear of the shifter hole.
That's a very good idea John Walker.
worked so far. maybe a bit more than 4", just so the weld doesn't hang up on the circular bushing in the support bracket when normally shifted into 2nd, 4th and rev. i don't yank engines/trannys unless i really have to. might want to mark it for "top" before cutting so the slight curve it has goes the right way, then be sure the front cup set screw hole faces left before welding.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 03-07-2008 at 03:55 PM.. |
