Guys, I have a stupid question. Im trying to get my ac unit out of the smugglers box on my 1970 and I cant. It is the factory one. I have taken off the lines on the drivers side and also unhooked the wiring. I also took off the mounting bolts. I cant see what is holding it in. I did a search and cant fing it. Thanks!!!!!
Did you remove the black plastic cover to the condenser and remove the thermostat and the expansion valve? Once those components and hoses are removed then the condenser will lift out along with its black box
I meant to say "Evaporator" and not condenser in regards to the unit in the smugglers box
Part #9 fits inside 25. Take out 4 screws behind passenger footboard to remove it and the evaporator box will pull straight up and out. Be carefull not to break the plastic drain tube on the bottom of the box when removing it. http://forums.pelicanparts.com/uploa...1214146939.jpg |
Thanks again guys. It was a big help. Im usually on Rennlist since I have a 993. now that Im starting to rebuild my 911t I need to hang out over here more!
I've been following this thread for a while and now have a question. I am putting A/C on a car that didn't have it before. I bought a evaporator box to put in the smugglers box but where does the round hole in the bottom go? There is no hole in the body of the car to mate to the evaporator box hole. I know I can drill one, but does that go into the center tunnel? If it does, are there suppose to be vent holes in the tunnel near the back seat, or do i have to put them in? If you look at the post two back, I'm talking about #1a.
(i) Is your car LH or RH drive, (ii) What is da body year? (iii) Vat brand evaporator box did you buy: Behr, VPC or other ? Assuming you wanted to place a Behr brand evaporator box in the car: Below is a picture of atypical early narrowbody "smugglers box". The green circle is around a steel cylinder which is welded to bottom of the well (you can dig through the parts schematics for PN). This cylinder or hollow stanchion butts up to the round hole in the LH side of the Behr brand evap box bottom. This provides the path for air to be drawn from under the driver's or LH side foot board. Outlined in yellow : small yellow circle on the bottom of the well is for the condensation drain tube for the evap box, and the yellow trapezoid is for the passenger or RH side air inlet plenum which will draw air in from under the passenger or RH side foot board. And if you were using the preferred Behr brand knee pad vent panel, which has three louvers on each side of the ashtray, you would bore a hole on the right side (looking at the picture) of the vertical drain tube through the firewall or bulkhead; naturally you will line things up to make these rather easy and fun mod's. |
134a Data point update. 91 degrees today. At 5'oclock temp setting, got vent temps 34 degrees on commute home at med fan speed. On max cold got vent temps of 29 degrees. :D :D :D
Thanks for the info. The car is a left hand drive 1978 911, and the evaporator box is a Behr. I already have the info on the yellow outlined items, its the green one i'm interested in. I'll have to look at it tonight, but you say it opens to behind the drivers side foot board. from memory that side is pretty well sealed by carpet except for around the pedals. That setup seems a little restrictive. Do you think there is an advantage to larger openings for the return air?
I finished my AC upgrade about two months ago on my 79, I think I want that new fan now.
The new fan is pretty great -- I'm very happy with mine.
I installed the Kuehl “Wirbelsturm” Evaporator Blower Motor this week. It is a very high quality and well thought out kit, backed up by incredible support. The original motor was squeaky, despite lubricating it. As the evaporator box was already open for an upgrade to the serpentine evaporator, the installation of the blower motor was easy. The Kuehl motor is much beefier than the original Bosch, so some modifications to the evaporator box fan platform (part #18 on the diagram above) are required. The included step-by-step instructions were very clear and easy to follow, and this part of the project took less than an hour. In operation, the Wirbelsturm is silent and pushes substantially more air at all fan speeds. Somehow, the entire AC system feels a lot smoother. It is a very worthwhile upgrade for the original fan motor. Paul http://forums.pelicanparts.com/uploa...1215350576.jpg http://forums.pelicanparts.com/uploa...1215350591.jpg |
Paul,
It looks like a pretty clean install. I used the retro air fan and was really happy with it. Does the Kuehl version get rid of the resistor pack under the passenger foot board? |
Yes, it is a very clean and straightforward install with no modifications to the stock wiring harness. This fan motor retains the stock resistor pack; it uses the original switch in the console and the new fan plugs into the car’s harness where the old fan did. The Kuehl variable speed fan controller, which Mark describes way back on page 8 of this thread, will allow you to get rid of the resistor pack.
Paul |
Paul,
Nice to know. The retro air fan gets rid of the resistor pack without the addtional expense of a new switch. They say loosing the pack allows a bit more flow but I'm sure it is irrelevant considering the amount of increased air these aftermarket fans pull. Here are a couple links to some installs for the retro air evaporator fan upgrade: http://forums.pelicanparts.com/showthread.php?t=411105 http://forums.pelicanparts.com/showthread.php?t=394694 |
Obligatory completion of project, “thermometer stuck in the vent” photo. Ambient temp was 80° and humid. Cheating a little, this shot is at Fan 1, although Fan 2 was not bad at 34°. For a while, I thought this thermometer was broken and stuck at 50°…
Thanks for all your help, Griff – couldn’t have gotten this far without your help and patience. Paul http://forums.pelicanparts.com/uploa...1215379522.jpg |
Very nice, where did you pick up that thermometer?
FINALLY, wrapped up my Rennaire installation yesterday. Unfortunately, I am only pulling about 35 degreees from the center vents. Today, I will be ordering a Kuehl Vent to bring more air to the business end of the cabin.
When I have some free time, my HVAC buddy & I will see ahat we can do to lower the vent temps a bit more but my black beast is actually cool enough to drive comfortably on warm days. This just took way too long, for various reasons. Anybody need a Desert Duty condensor at a very fair price? |
Mike: You have mail.
Mid summer check in. Doing so because of alot of A/C threads leave me wanting more in terms of follow-up after the project is completed. How's it doing?
91 degrees here yesterday and partly cloudy on the commute home yesterday. At 3 o'clock temp dial setting I got steady vent temps of 43 degrees with fan at full speed and 38 degrees at med speed. Pretty good - no complaints. If it had been sunny cabin greenhouse effect would have increased vent temps by about 5 degrees. My shirt was completely dry after 45 minute commute and the passenger seat was cool to the touch. If I run the temp dial at full cool for an extended period of time at high ambient and humidity conditions the evap tends to freeze up. If I run it at the 3 - 5 o'clock position on the dial, no freeze ups/reduced air flow at the vents. At really high ambients in stop and go traffic after car is heat soaked (e.g. lunch trips) the system still performs good but vent temps are clearly higher (high 40's or low 50's) until I can get the rpm's and air flow up. Very few days this summer with a wet shirt back - really only when car is heat soaked at lunch - I don't care how well your A/C is working, if you sit on 100 degree leather seats you're going to sweat. Possible tweaks? Wondering if changing out my rear deck lid condenser from OEM tube and fin unit to a high efficiency serpentine unit would help on the mid-day extreme conditions. Also wondering if I could drop the rear deck condenser down 1/2 to 3/4" via spacers to maker room for larger fans above the condenser to create more air flow over more area. vs. this set up where I've got fans covering about 1/2 of the condenser: http://forums.pelicanparts.com/uploa...1217935310.jpg |
Mark,
Based on your history of temps I'd suggest focusing on the thermostat ;) |
I like that fan setup on the rear condenser. Does anyone have "upgrade" ideas for the airmover on the front condenser? Is there anything to gain with better airflow up there? Could be less expensive than a new condenser but would likely require some custom work.
I have the complete $1450 R134 Rennaire kit installed and I have a top quality robinaire vacuum pump and mastercool gauges and I know how to use them.
I couldn't get vent temps below the mid 40's with the fan on high in my venetian blue '87 turbo on a sunny humid day in the mid 90's here in south florida. I bought this big serpentine fenderwell condensor with the 10" fan included that goes in front of the left rear tire at a slight angle to fit and it made alllll the difference. You couldn't fit a bigger condensor in there... http://www.***********/cgi/sh000001.pl?REFPAGE=http%3a%2f%2fwww%2eallzim%2eco m%2facatalog%2f&WD=conditioner%20air&PN=911_COOL_K it%2ehtml%23a911_2e573_2eADD_2eCOOL#a911_2e573_2eA DD_2eCOOL Incredible difference. Now I have low thirties out of the vents with the fan on high. Feels really good when the heat and humidity south florida sauna effect feels like 105 degrees outside. |
Thanks! |
From the information that I have gather up it seems that when you get a more efficient engine lid condenser it will exchange more heat which has to flow over the engine, thus that can raise the oil temperature. So you might improve the A/C, but at the expensive of the oil temp.
I'm with "hocoles", I think the next step beyond what's already out there is the front condenser fan motor. If we have upgraded evaporator fan motors why not a upgraded condenser fan motor... I'm close to re-charging my system after installing a Rennaire evaporator and ProCooler from our host, and a Retroaire upgraded blower motor. If it works out I'll do a follow up on it. |
installed pic
My car happens to be on jackstands with the rear wheels removed for other reasons right now so I just went out and took a pic of it.
I have 18x11" 996TT wheels with 315/30x18 tires on the back and there is still 2" of clearence from the tire when the car is on the ground... no problem. It's a really well fabricated kit with an aluminum debris/splash guard and everything including the correct length mounting screws and a barrier hose to go to the rear deck lid condensor that I didn't use comes with the kit. Instead I spliced into the 19.5' long high pressure barrier hose using the supplied fittings in the kit, into the Rennaire hose that I already had installed. I used two wide all stainless USA made name brand hose clamps and tightened them real tight on each fitting for peace of mind and less chance of R134 leakage. Professionally made crimped on fittings on custom length hoses is better but this was way cheaper and it's not leaking It's hard to see from the flash glare but there are 3 self tapping sheet metal screws in the top right corner of the aluminum splash gaurd mounting it to the fender well. The screws are short so they don't go through the leather interior in that spot! I have weltmeister adjustable spring plates that you can see so I don't have to remove the condensor to adjust ride height or corner balance the car. You can also see by looking at all 4 corners of this 18"x12.5" condensor that a bigger one wouldn't fit. Thats a 10" puller fan on there that comes with a fused relay in the kit. Gee... I'm starting to sound like a sales rep, but I'm not, I just wannt to help out using my experience so I'm gonna shut up now...http://forums.pelicanparts.com/uploa...1217949831.jpg |
Has anyone purchased AC tools from viot.us? I need to stock up to finish my project with pretty much everything (gauge set, v-pump at a minimum).
Mark
You might want to consider adding test ports on the suction and discharge lines at the compressor. A friend of mine just finished a similar installation on his 77 911. The test ports on the compressor did not give him good readings after he had charged the system. When he questioned the compressor seller they said they would not rely on the ports at the compressor, better to install ones on the hoses. Steve Sanders 86-911 cab |
I'm a little leery about he price of the Griffiths serpentine evaporator, but was reading this thread and wondered about the benefits of converting to a R-134a expansion valve instead of the original R-12 one. Is it worth it? I'm not getting very cold temps, about 50 at the vent when it's 85 out and I'm doing 60 mph.
Where can I look at the three fans on the rear condensor? Thanks
sub
You won't gain much, however to start what is the superheat of the two valves you are comparing.
http://www.the-fan-man.com/ My install thread here: http://forums.pelicanparts.com/showthread.php?t=312760&highlight=adding+fans |
haven't got a clue. The one in the car is for an aftermarket R-12 system but an OEM Porsche evaporator. When going through the system years ago, I believe I took the valve apart to "clean, check, whatever" and just screwed it back together, with no thought to whether it needed to be "adjusted" for superheat, which I don't totally understand. I guess my question is whether an expansion valve designed for R-134a would give better cooling. Oh, and your system looks fabulous, but out of my price range to experiment at this time. I may well buy your new and improved evaporator blower fan, THAT I'm pretty sure will go a long way towards improvements. |
Yes a new expansion valve for R134 would cool the car better.
If you buy a new generic one thats all you will get, unless you buy a more expensive OEM R12 one from a porsche dealer. R134 molecules are smaller than R12 molecules, so the orifice adjustment in the expansion valve should be a little smaller for R134. I've heard of people succesfully turning the allenhead superheat adjustment in the origonal R12 expansion valve inwards 1-1.5 turns when converting to R134. Quality aftermarket expansion valves are only around $30 so I'd just put in a new one made for R134 to be confident of the correct superheat setting and how well it's going to work. |
Thanks, that is kind of what I thought. I'm sure mine is way off of its proper setting anyway, because I fiddled with it and turned the allen head inside not knowing that I wasn't supposed to futz with it.
| All times are GMT -8. The time now is 11:54 AM. |
