-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   A/C Upgrade Project starts tomorrow! (http://forums.pelicanparts.com/showthread.php?t=397009)
mthomas58 05-13-2008 08:39 AM
Originally Posted by tsuter (Post 3939376)
I wonder if you could take a reading of the temperature off the body of your compressor after a 20-30 minute run on A/C w high cooling. Thanks.
Also interesting would be a temp reading off the top/front of each condensor vs the vent temp at the same time as above.
Are your condensers in parallel with #6-6-6-6 side and #8-8-8-8 side lines or in series all #6 lines? If series, what is the order from compressor to proCooler?
Unfortunately, I don't own an IR Thermometer but let me check with some neighbors.
What I can tell you is that the suction line at the compressor was not cold to the touch at the conclusion of charging but I have not checked it after running the car on the road at higher RPMs with good airflow (but I will). The ProCooler was ice cold and sweating.
Any idea what the "normal" operating temp range is for the compressor?
I believe all of my high side hoses are #6 and all suction lines are #8. High side lines run from the compressor to rear deck condenser to rear wheel condenser to front of rear wheel condenser to front bumper consenser to ProCooler to Evaporator. Suction lines run from Evap to Procoooler to Compressor.
Tsuter, looks like you're already in the 90's in San Antonio. How's your system cooling?
tsuter 05-13-2008 10:22 AM
96F Sunday 103F at the condenser gave 32F at the vents on high fan speed and temp dial at about 80-85%. I'm expecting a 70-75F differential when its 110-115F. Over 40F vents at any ambient would be disappointing. We'll see.
But I am interested in compressor temps. Not sure what they should run at. I may be a bit low on charge.
mthomas58 05-13-2008 11:52 AM
Check out this site:
http://www.climatictesting.com/Automotive%20AC%20System%20Test%20Stands.htm
Says that compressors may run at 250 degrees
Mike Andrew 05-13-2008 02:20 PM
I am still not there. A few distractions have taken precedence the last several days. I hope to wrap everything this weekend but that is iffy as it will only be 60ish here and that's a bit cool to charge.
mthomas58 05-13-2008 02:39 PM
Originally Posted by CatSkynr (Post 3931420)
It will be concealed. No need in disconnecting anything. I made loose fits before pinning the lines to the pan. You will need to move inboard to the next indention level on the pass-side pan after making the cross run which is roughly 6” inboard to have enough slack in the back. By the time you make it towards the rear, follow the indentation to fall into the original trench (just past the rear door jam when it makes the turn inwards). Pre-drill your pilot holes into the pan by holding the clamp in place over the hose then caulk the original holes closed. When you do this, you end up with exactly 2 unused C-clamps (where the line ran under the splash guard), you reuse these on the front-cross run. Fits perfect, you’ll see when you unbutton your line. Then you will need a few ADEL clamps to pin the line in place next to the hi-side run. Just tack them on the other side of the c-clamps, makes for perfect spacing. I zip-tied my lines all in place at the drier side first, then clamped them to make them look uniform. As you can see in my pic, I spaced them the width of the tie, which worked perfect. One tie loose around ALL the lines, then zip a tie around that looped tie in-between the hoses. Snug them all up.
I plan on making a skid plate for the front and using the original stone guard plastic to make a pan underneath my procooler runs; just to tidy things up as this can be seen and is not hidden. The plastic provided for the stone guards I use at work all the time. It can be molded very easily with the use of a heat gun. I may use this stuff for a skid plate over the front cross run so I can mold it around the hose, then bend a U clamp shape around the procooler side to cover the wheel-well portion that sticks out.
Cars at the mech now getting a fresh clutch so should be a little while before I get back on it to finish things up. I just wanted to get the mass of the work done while the weather is still nice here.
I see one less line in your ProCooler hose jungle than mine. Do you have a front bumper condenser - could not find the year of your car but may have missed it.
CatSkynr 05-13-2008 02:45 PM
My car does not have the front condenser. It’s a 77 S.
Plus the pics do not show the hi-side running from the rear condenser to drier. That was the last thing I ran. You can see the c-clamp where it is to go. It is just along-side the rest running up. The dirty hose is the gas filler overflow.
mthomas58 05-15-2008 08:07 AM
Woo hoo! It's 70 and cloudy today and I was running on the Interstate earlier today. Tested Max Cool setting and med fan speed to see what she would do. Got vent temps down to 24 degrees!!!!:D Pretty impressive for 134a in a 911 IMO
Mike Andrew 05-15-2008 09:25 AM
I just hope to come close to mid 30's at the end of this project. I am truly impressed with those numbers. Cold enough to keep food & drink cold.
mthomas58 05-18-2008 11:19 AM
I'm ready for summer! Picture is a little dark - 23 degrees vent temp! In garage, 75 degrees ambient, max cold, med fan speed & engine at 2000 rpm.
http://forums.pelicanparts.com/uploa...1211133363.jpg
Re-cap of new, four condenser system:
OEM tube and fin rear deck condenser with 3 spal fans
New barrier hose
Duehl Kuehl fan assisted fender condensers (2)
Kuehl Serpentine Evaporator
1/4" foam insulated and foil wrapped evap box
Kuehl Serpentine front condenser
Kuehl Variable Speed Fan Controller
RennAire ProCooler
Rebuilt Nippondenso Compressor
Converted to 134a
CatSkynr 05-26-2008 01:25 PM
Finished. I connected everything up and did a 24hr static nitrogen pressure test at 175lbs. I used my oil injector with the nitrogen and put in 10 ounces of mineral oil and a slug of dye. Next day I evac'd for 3 hrs and charged everything up. At ~80deg ambient sitting in the garage I got cold enough for the compressor to cycle when it hits 32 deg. Average is 35deg, so we'll see how it works when in gets in the triple digits.
http://forums.pelicanparts.com/uploa...1211833352.jpg
http://forums.pelicanparts.com/uploa...1211833295.jpg
http://forums.pelicanparts.com/uploa...1211833416.jpg
http://forums.pelicanparts.com/uploa...1211833433.jpg
PSJoyce 05-26-2008 03:22 PM
Me too. Nothing like nice weather to finish off this project that was inspired by this thread.
Living on Cape Cod, I didn’t need to improve the system too much, but I did need to take care of a very leaky compressor. New Kuehl center vent, serpentine front condenser, hi-low switch hose, receiver-dryer and rebuilt compressor. Followed Grif’s excellent instructions, flushed and vacuumed for a total of six hours (held vac at -29” Hg for over two hours) and a careful charge with 134a. Vent temps at 37° on a 75° day.
All in all, a satisfying project. I still plan to seal up the evaporator box.
Thanks for all the great information – I would not have attempted this without the great help here.
Paul
http://forums.pelicanparts.com/uploa...1211840352.jpg
bonaturtle 05-26-2008 03:42 PM
subbed, want to do this for the summer as well, or have my shop do it I mean :D
mthomas58 05-26-2008 04:30 PM
I played golf the other day. Ambient temp was high 80's and car was parked in ths sun and heat soaked for 5 hours. I was getting 43 to 45 degree vent temps and thought those #'s were a little high. Consulted with Griff and he agreed. At 7oz of oil he thinks I'm 1 oz overcharged which might be impacting performance. He suggests dumping out 1 oz of oil and recharging with 36 oz of 134a using a 30 lb container and a scale. My system continues to work GREAT. I'm going to continue to chart my vent temps and ambients and wait till temps get in the 90's before doing the evac, oil removal and recharge.
mtbguy 05-26-2008 06:07 PM
I can't wait to finish mine- I have all of the parts on hand now and am building my "Jim Sims" subcooler presently- hopefully I will be able to do the AC install in the next week or two.
Good job to those with these low vent temps!
Mike Andrew 05-27-2008 04:25 AM
I have virtually everything plumbed in except the TXV & condensor connections to the Procooler which I will do just before evac. & charge. However, I hit a snag with compressor pulley interference and am awaiting a compressor with a turned down pulley from Rennnaire. So, I am still in limbo.
CatSkynr 05-28-2008 10:39 AM
Well we hit 90s yesterday. With the car sitting in the sun all day and a cockpit temp in the triples, it took about 5mins and the vent was blowing 38. What I find amazing is that the condensers don’t get hot! (after ~45 minutes driving in-town) I can literally lay my hand on the deck lid condenser and it’s just warm, compared to the old York days. Same with the wheel-well; although I can’t really lay my hand on it due to space, to the finger touch they are just warm. The compressor definitely gets hot. The pro-cooler is cold and you can feel a temperature differential between the inlet and outlet of the low-side into the sub-cooler. So far I am really happy. As screwed up as it sounds, I can’t wait for a day of triple digits to really test this system out.
PSJoyce 05-28-2008 01:11 PM
Well, sometimes it’s the simple things.
Checking the vent temperature -- while the front trunk lid was open -- to make sure I hadn’t ruined something new while re-sealing the evaporator box to replace all the foam that had gone to dust, I noticed I could see daylight through the center dash A/C vent. Somewhere along the way in the last 24 years, the duct to the center vent had slipped off the vent. Reaching around from the front, but mostly reaching in through the clock hole, I was able push the vent back into place. I had always wondered why it didn’t seem like a lot of air was coming through the vent – much better now.
Paul
Wickd89 05-29-2008 08:12 AM
Man, you guys are awesome!
My '89 needs a new compressor and evaporator; after a professional inspection. They actually said everything else was fine (sure)...
I would love to do this full project but lack the time and/or $$.
Any Pelican experts in Socal that want to do this as a side project on my car someday? Great project for someone out of work or retired that has major skills!!SmileWavy
Since I have a Cab, this is a low priority project, but would be really nice...
GH85Carrera 05-29-2008 03:30 PM
A/C work is not difficult. You can do the vast majority of it yourself. The only part that is above the average home mechanic is the vacuum & charging. Hire a pro for that part if you don't have the knowledge & equipment. It all comes down to how much COLD air is worth to you.
hcoles 05-29-2008 07:13 PM
That's what I plan to do but where is there a very good AC shop that knows the older (e.g. 1989) Porsches and follows all the evac and charge proceedures mentioned in this thread and others... in northern CA or do I need to drive to LA to get the fricken thing done correctly?
Mitch Leland 05-29-2008 07:46 PM
A/C Ducting...
Paul
Paul gave me a good heads up... My A/C is barely cold, but beyond that it doesn't blow very hard. I want to be sure that the dash grill is lined up and the return air opening at the evaporator is clear.
Also I read on the PCA Tech site that a guy sealed off his passenger side foot well vent which increased the air flow from the dash grill. It might be worth trying as it doesn't involve anything permanent.
If I don't get any improvement in the A/C performance after that I'll consider some of the up grades.
JeremyD 06-01-2008 08:21 AM
Just wanted to add to this thread - I was coming back from Sebring DE and just happened to have my hand held thermometer in a carry all next to me so I thought I would shoot a vent temp - this is after a hour and 45 minutes in the car. List of changes:
All from Rennaire:
Desert duty front condensor
Serpentine evaporator
I lined the evaporator box with stick on foil back insulation
Barrier Hoses
Sanden 507 Compressor
new stock Receiver/Dryer
r134a
I'm pleased the way it turned out.
http://forums.pelicanparts.com/uploa...1212333594.jpg
scottb 06-01-2008 08:39 AM
Originally Posted by JeremyD (Post 3976619)
Holy ice cubes, Batman!! :eek::eek:
Barrpete 06-01-2008 09:18 AM
Shouldn't you be wearing gloves?:D
deshetlr 06-01-2008 09:20 AM
Jeremy why did you choose to go with the stock receiver/dryer over the Pro-Cooler? Looks like you are getting great performance without the extra complexity.
JeremyD 06-01-2008 10:27 AM
Cause I have 16 x 8 (951) wheels on my car 225/50/16's and I have heard some people having fitment issues with the pro cooler.
I figured that a new receiver dryer was 1/4 of the cost - and I could add one later if I needed to.
It was a gamble and a compromise - but I'm ok with that. BTW it was 92 on the bank temp sign down the street where I took this picture and pretty darn humid.
BTW that is a "F" not a "C"
http://forums.pelicanparts.com/uploa...1212341215.jpg
kuehl 06-01-2008 01:20 PM
Jeremy,
Is your ac's thermostat system working properly?
Mitch Leland 06-01-2008 01:46 PM
Jeremy,
Wow, that's unbelievable, and without adding an extra condenser... I wonder why these vent numbers are all over the board?
I'm assuming the barrier hoses have nothing to do with the temp, but only with the bleeding off of the freon charge. So that leaves the front condenser and evaporator as real upgrades to reducing the temps on your car.
Do you additionally contribute the better cooling to the insulation of the evaporator box? If you hold your hand in front of the vent grill with the fan on high setting how far does the cold air throw from the face of the grill? My car is about 10"-12"...
PSJoyce 06-01-2008 01:47 PM
I compared an infrared thermometer, and a standard digital probe thermometer on my A/C vents the other day. The digital probe thermometer showed 40°, and the infrared varied from 14° all the way down to 0°. I shot the back of the probe thermometer with the infrared, and that was also 40°. I’m not sure of any of the physics, but the probe thermometer seems a better choice for measuring vent temps.
My other standard of comparison was my bare hand, and that got pretty chilly.
Paul
JeremyD 06-01-2008 02:39 PM
Originally Posted by kuehl (Post 3977014)
Jeremy,
Good point Kuehl - My thermostat switch is now on on off switch that I have to cycle - so yes, technically a thermostat switch would have cycled the compressor off before getting that low - I had a problem with the switch - but will replace it with a new stock one now that I know the system is working optimally.
As far as the thermometer is concerned - no I have not had it calibrated - yes it could have been off - Just one man's experience. I'm not trying to set a record of anything (BTW the black plastic surrounding the vent was 39 degrees)
JeremyD 06-01-2008 02:45 PM
My car ran at Sebring for a DE - was out in the sun all day - top up, windows open. at 4:00 I packed the car back up - put the windows up (I have a convertible) - Dark blue interior.
By the time I got to the gas station in down town sebring - I was feeling comfortable. less than 20 minutes and I cut the fan switch from full to 3/4 .
So yes, it seems the desert duty front condensor, coupled with a new compressor and a evaportor can have measurable impact on your stock AC system. Can it get colder? Sure. It would also be nice to have a little more fan volume - and less noisy - but is my car much more civilized in the summer? you bet.
kuehl 06-01-2008 05:13 PM
Infrared or non-contact temperature measuring is not tricky as long as you know what you are measuring and the limitations of the tool. If the tool has distance-to-spot ratio or D:S of say 24:1 that would mean when you are 24 inches away you may be measuring 1" diameter. The infrared tool can not measure the air temperature but it can measure the temperatures of the surfaces, and there are some surfaces and materials which can be provoking or testy in terms of the blackbody radiation emitted from the object: the angle in which you hold the tool in respect to the surface you are measuring is important especially for when the object has an emissivity of less than .9; the emissivity of the object, such as flat black vs. shiny reflective black can come into play with accuracy as well.
I prefer to use something with a thermocouple, and we try to use the same make and model unit with NIST (National Institute of Standards and Technology) traceability to insure what we are seeing is realistic.
I won't say whether you actually were getting 18F or not as "anything" is possible; I've driven my evaporator core below 9F with R134a playing with various charge rates and combinations of components. But what is more important is how well the system overall performs in removing the heat from the vehicle consistently and without crashing the compressor. So, safe high side pressures are what you want to focus on now.
You know that once you near 32F in the evaporator box on a humid day with the circuit you have you'll just have to turn the system off and let the ice thaw; so its time to fix the thermostat for sure.
The bottom line is that you felt comfortable after making some mod's and doing a proper evacuation and charge in you new ride, Cab's can be challenging to keep cool.
I might have something for you in terms of more CFM in the next month or two, we are still "testing" as they say.
Griff
Mitch Leland 06-01-2008 06:02 PM
After reading some previous threads I decided to look at the manifold connection at the back of the dash vent grill. As was suggested by an earlier posting that you can remove the clock for access which I did. The manifold was 1" away from the dash grill housing. I removed the fresh air blower, the plastic "Y" and related hoses. Once I had the A/C vent hose off of the manifold I was able to reach in through the clock hole and re-set the manifold housing back on to the dash grill vent. In fact I don't think you can get at the manifold housing from the trunk no matter how much you remove. So I probably removed things I didn't really have to.
The one thing that I think might have been a problem is that there is a metal tang sticking out of the firewall of the trunk that is directly under the A/C vent hose. When I re-installed the A/C supply hose I put the hose clamp over the metal tang so now the hose is anchored to the firewall which hopefully will keep the vent grill manifold housing in place.
I'm now getting a lot more air, but still not cold enough for hot Texas summer days. If Griff comes up with a higher CFM motor I'll be the first in line. Hopefully you'll be able to run it slower and get the same CFM we're getting now, but it will be quieter, at least you'll have choice of more air or run silent...
The corrugated hoses sure don't add up to a very efficient way of delivering the air. I bet if you could find a metric SCAT hose it would allow better air flow. Any thoughts out there on this.? It appears that you can improve on our A/C, but it takes a lot of small improvements to make it really work... and money...
mtbguy 06-02-2008 02:01 PM
Capillary tube casualty?
I finished removing my old system this weekend after the weather here is getting hot and I am finally finding some free time. I was REALLY glad I pressure washed the underside of car recently because this was a dirty job.
My only casualty was I forgot about the capillary tube with temp sensor inside of it when removing evap box from car, and bent it up a bit. I can't seem to find a replacement one online and wonder if I just carefully re-install it would work okay. I don't think it was punctured/ruptured- just bent. Is this a universal part that can be bought at local A/C supply and spliced into system?
Now its time to braze on fittings for my SLHE (suction line heat exchanger) -Jim Sims subcooler.
Barrpete 06-02-2008 02:32 PM
I just bought one from Pelican for $50.
P/N 911-613-121-01-M145
It's on the electrical switches page not the ventilation/AC page.
mtbguy 06-02-2008 04:09 PM
Thanks Barrpete- that explains why I couldn't find it. Did you bend yours up also, or do they die of old age?
Barrpete 06-03-2008 07:31 AM
Apparently they die of old age. My AC was working fine & then suddenly no cold. Fans still blowing fine but compressor wouldn't kick in. Measured the voltage at the compressor & only got 7 V. Bypassed the switch & voila 12V again.
mthomas58 06-05-2008 04:25 AM
How about posting some pics of your SLHE? BTW, just sent a PM regarding your capillary tube with some recommendations.
mthomas58 06-06-2008 04:24 PM
Commute home today............93 degrees........... 34 degree vent temps! Charlie, you're the man! Couldn't be more pleased with capability of the new system.
This was at the 5 o'clock temp dial setting and med fan speed.
GH85Carrera 06-06-2008 05:55 PM
It was 94 here today. I drove my toy to work since it was Friday :) I had to turn the A/C down to medium fan speed on my trip home. It is only a 12 mile commute but I was getting cold.
