Seems to me that if you take a 55 gallon drum filled with refrigerant, set it on a block of ice and build a fire on top the pressure will be equal throughout. Other than the minor effects from frictional resistance to flow how does 12-15 feet of hose differ? |
Thanks Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT Last edited by DaveMcKenz; 08-06-2015 at 09:35 AM.. |
Why would the molecular density of the gas be different at one end of the hose vs the other? The temperature at the inlet side of the rear lid condenser varies pretty dynamically from the temperature at the inlet to the R/D, so would you say there is a pressure different in accordance with temperature change? |
Read Boyle's Law.
Brain-twister..
How is it possible for refrigerant pressure to EQUALIZE so quickly THROUGHOUT the system before the low side (evaporator, etc) WARMS to OAT nor the high side COOLS to OAT if BOYLE's law prevails? |
2) Just because the pressure equalizes within the system, does not mean that it equalizes to a corresponding pressure that would be found at OAT 3) Once fluid flow ends (shut off compressor) the gas within the hose will reasonably quickly stabilize to a constant pressure (from transfer of actual atoms from high to low pressure regimes). However, that stable pressure will be based on averaging pressures within the hose, and will require that some gases heat up and some cool down. The final static pressure will have some final static temperature, and that will NOT be OAT. NOT. NOT. NOT. 4) Don't forget the fluids in that hose! Half the system has hot pressurized liquid even when you shut off the flow. Hot pressurized liquids do not follow the ideal gas law. LIQUIDS. LIQUIDS. 5) Your silly 55 gallon drum misses one key element that our A/C system has, and that is FLOW. FLOW. FLOW. Sometimes I think you miss words, so I will repeat the key ones. FLOW.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
