2488 with about 1/8 tank of gas... 510 chp.
Ok I'll play too, full tank of gas, tools & spare on board
1976 C3 targa 2755 1995 993 Coupe(2wd) 2789
With 18" Turbo Twists 265/35 rear, 225/40 front, 3/4 tank of Gas 2380
![]() With 15" Fuchs 245/50 rear, 225/50 front, 1/2 tank gas 2260 ![]() ![]() Fuchs Win!!!!
Keitho64 05 GTO 00 911 C2 64 Corvair Chicago Burbs; the Anti-Dragon... 11 turns in 318 miles |
Your other wheels and tires weigh 120lbs MORE than the fuchs??
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Jeff - I could not believe the difference either but the scale does not lie. The Turbo Twists require 3" spacers on the rear, 1" on the front. I think the tires, wheels, spacers etc. all contribute to the difference. Keep in mind there could be a 3 to 4 gallon variable of gas as well. While not a lot, it all adds up.
One could argue that is one day the scale changed that much but the scale I used is at work and is calibrated for DOT so I assume it to be accurate.
I just weighed mine. The car and me are both going on a diet. I need to loose 20lbs, and the car needs to loose 140.
![]() 1976 Targa 1985 3.2 engine Carrera power doors Carrera rear flares Carrera front spoiler & Fog lamps Two amp stereo with 2 8" subs behind the seats Carrera 8-way power seats. 16" Fuchs Big-ass Autozone battery. Alarm system. 2739lbs with a full tank of fuel. Today I pulled the AZ battery and replaced it with an Odyssey for an instant 21lb savings. Next to go will be the window washing system, and then the power seats, and rear seatbacks.
1976 911S Targa, Carrera bodywork, 3.2l engine. Last edited by Roc Doc; 12-24-2008 at 07:00 PM.. |
3,000# without me @ 3/4 gas
weighed same at 3 different Oregun truck stops rounded to nearest 50#. also no AC full compliment of tools spare fuel pump, alternator, CD box etc, at least another 50# of fix-me-up parts, 5# + 2.5# halon extinguishers, 20# of H2O, and 50# of Dynamat. ![]() ![]()
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
~2435# with a full tank of fuel... scale was "guaranteed within 20#"
2007 997 1998.5 Ram 2500 Cummins |
Had my car corner balanced total weight was 2,787
full tank of gas Full oil Bone stock (Strut tower bar, Bilstein HD's, and Kumho MX'S) P.S - 85 is the best year Carrera!!!! |
2204lbs with 1/4 tank
spare wheel, tools,jack and brace across doors
83sc targa BBT |
Czar of C.R.A.P.
85 Cab
2550# 1/2 tank 7/8-15 fuchs with Hoosier A6 Stock passenger seat aluminum race seat no jack or spare CAT bypass muffer deleted 1984 Cab with Hardtop At last check 2212# 1/2 tank 7/8-16 ROH with toyo street tires (heavy) no interior aluminum race seat open headers 3/4 cage Huge battery At weighing the top was off. Top weighs 48 lbs. fiberglass bumpers
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
Road warriors don't worry about weight while carrying what they need...only effete little track guys believe the mantra: "You cannot spend too much or weigh too little."
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
MBruns for President
I don't feel so bad now about my not so fat a$$ cab weighing in at 2860 lbs with a DAS bolt in rollbar 3/4 tank spare etc all there - even had a folding chair in the front compartment. 8 & 9 / 16 fuchs.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Air Medal or two
Me too !
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
I came in at 2535 wit half tank of fuel and no spare tire.
Brent Lineker 1975 911S weber conversion. |
My 1988 Carrera is 2720 lbs, w/ 1/2 tank of gas and no A/C. I don't even want to know what my Carrera 4 weighs...
2008 Porsche RS60 Spyder 2005 Jaguar XJR 1994 Porsche 911 Carrera 4 1988 Porsche 911 Carrera (Sold) Last edited by hkiang1; 12-25-2008 at 10:31 PM.. |
82 Euro SC
2431# with half a tank no A/C no sunroof racing seats no back seats 5 point harnesses DAS roll bar fiberglass IROC bumpers 15" Fuchs 7s and 8s air pump removed stock H/Es stock cat no muffler Since that weighing I've removed the entire interior for a cage install. All carpet, sound padding, stereo and 4 speakers, door panels, and the floor coating. I suspect even with the welded cage it will come in under 2400. More pics in my sig.
Gone 92 C2 82 Euro SC race car 993 C4S 3.8 84 Euro Carrera |
Max Sluiter
Nice looking car.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
77 911s targa w/ 3 L engine w/ 3/4 tank of gas - 2680 lb
![]() Do you sometimes run with less oil than you need?
