Green Skull 006
Jim Garfield's Avatar
CRC MAF sensor cleaner
Has anyone tried this stuff?
S Reg 823 R Gruppe 246
1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha"
"It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field.
Old 04-11-2008, 02:58 PM
sudo apt-get purge 930
equality72521's Avatar
I've used it on Ford trucks with good results.
--clutch-monkey
Old 04-11-2008, 03:04 PM
weird, I just read a big huge thread about it on a m5 board. Most of them say it works well.
Old 04-11-2008, 04:09 PM
Worked well on my Boxster.
Rob
1980 SC - 2011 Tiguan - 2018 Tesla M3P
Old 04-11-2008, 04:43 PM
Green Skull 006
How is it applied? Is the air filter removed and the CRC sprayed into the opening?
Old 04-11-2008, 05:11 PM
Used it on the slk, our current ML320 and the previous ML320. Works great. You have to remove the sensor itself from the plastic housing and spray the wire down. Thats about it. Clear the MAF code if you received one. On mercedes this is usually P0170 and P0173.
Mike
Old 04-11-2008, 05:17 PM
Less brakes, more gas!
euro911sc's Avatar
I use it on my Bug. You simply spray it on the wire. DONT touch the wire! Let it air dry and spray it again. while it drys for the second time clean your air filter and wipe down the engine area while checking for anything loose or amiss. Before re-assy clean the wire contacts of the connectors and be done.
Enjoy!
Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 04-11-2008, 06:30 PM
I'm not sure what car you have but the "wire" everyone is talking about only appears in Heated Wire devices. I don't believe Porsche implemented these until the 993? The vane device that is on Pre '95 (again not positive on year) cars is a totally different animal. All I can add is that in the Mustang world it was out of fashion to clean the MAF; a few people were having idle issues afterwards and most found they were already pretty darn clean anyway. I've never been a big fan of whole-sale dousing of anything for fear of getting liquid stuck where it shouldn't be; washing away grease, and exposing plastics and rubbers to solvents that may dissolve them.
Old 04-11-2008, 11:12 PM
Green Skull 006
Originally Posted by vreference View Post
I'm not sure what car you have ..... I've never been a big fan of whole-sale dousing of anything for fear of getting liquid stuck where it shouldn't be; washing away grease, and exposing plastics and rubbers to solvents that may dissolve them.
It's for a 3.2, and the literature says that it doesn't damage plastic or wires in the sensor like solvents would.
Old 04-12-2008, 09:24 AM
All the Motronic 3.2s had mechanical "vane" MAF sensors as far as I know. Personally, I wouldn't get near mine with any liquid that comes out of a spray can. Or any liquid that wasn't applied precisely and methodically for that matter. If the vane itself moves freely I'm not sure how much cleaning one would require. But that's me and I also don't pressure-wash engines so take it with a grain of salt.
1989 Carrera 3.2L in 993 bodywork
Old 04-12-2008, 09:38 AM
ianc's Avatar
All 3.2's with DME have the vane sensor, which is a VAF (volume air flow) and not a MAF. Using this on them won't do any good at all...
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 04-12-2008, 12:19 PM
Green Skull 006
Thanks, I knew that it wasn't the hot wire setup, but I thought that it was still considered MAF. I'm glad that I asked.
Old 04-12-2008, 02:27 PM
