spring plate bushing - swap left/right?
I took my spring plates out today. They are quite eccentric, though the rubber seems to be in decent condition. The spring plates look symmetric to me.
Has anyone ever tried just swapping the spring plates side-to-side? That way, the compressed (thin) part of the bushing ends up on the bottom, and the fat part ends up on top. Of course, after 5 to 10 years, the problem will return, but I'd have another 5 or 10 years with stock rubber pieces. I have the Neatrix replacements, but they are quite a bit harder than the stock bushings ... I measured the bushings in several places, they are a pretty consistent 72 to 73mm diameter. I don't track or autocross and could care less about "excessive" suspension deflections caused by "soft" stock bushings while driving ... Comments?
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Used Up User
Neatrix bushings PEL-PP909976 $51.98.
This: ![]() Versus this: ![]() And since the forces on the bushing are rotational - not just downward - I think the $52 is well spent. fwiw Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
you can swap sides. it is a good plan. free!
poof! gone |
