heat exchange gasket question
Hello, I have a 1892 SC, and am about to embark on oil return tube replacement. If I get into a situation and need to remove my heat exchanger(s), can I re-use the existing gaskets, or should I replace them with new? Also, are there any other gaskets needed associated with heat exchanger removal that should be replaced with new?
any input on this would be appreciated
thanks,
Bill
Old 04-17-2008, 08:19 AM
dtw dtw is offline
GAFB
Hey Bill! Yes, you'd need to replace the HE gaskets and if you removed the muffler, also the muffler/HE gaskets. But, you shouldn't really need to remove the HEs for the job. I've done it with them in place. It is a PITA, but very doable.
Several BMWs
Old 04-17-2008, 08:37 AM
175K911's Avatar
Agree with Dave- try with them on. Besides if the HE's have never been off before, you run a very real risk of breaking some of the exhaust studs which will be a LOT more work than just taking your time to replace the return tubes with the HE's in place. I assume you're talking about using collapsable return tubes?
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 04-17-2008, 09:22 AM
thanks guys. I'll install my collapseable oil tubes with exchangers on. I am replacing lower valve covers and gaskets; can I do this with the heat excahgers in place?
man, this group is great for a newbie like myself
Old 04-17-2008, 10:01 AM
sudo apt-get purge 930
equality72521's Avatar
Yes, you can replace tubes and covers with the HEs on. Tubes will suck but covers will be fairly easy.
--clutch-monkey
Old 04-17-2008, 12:39 PM
