Sportomatic Torque Converter
Has anybody had problems with the sportomatic torque converter oil seal surface and / or brass support bush and solved them without having to buy a new converter?
The sealing surface on my torque converter is grooved from years of wear. I was thinking of using a speedi sleeve or similar. Has anybody had success with these?
The brass support bush is another matter though as there are no individual spare parts available for the torque converter from Porsche. Fichtel and sachs are the OEM but I don't know whether I can get this part from them. Any ideas?
I've attached a photo of the torque converter.
Norbert
1971 911E Coupe Sunroof S-trim
Old 04-19-2008, 07:59 PM
Bird. It's the word...
Fishcop's Avatar
Norb, ring me... I have one sitting here, needs the ring gear re-welded, but it has been upgraded to a higher stall spec (good thing).
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 04-20-2008, 12:49 AM
Norbert,
have the same problem with my 69 sporto
changed the oil seal (3 times ) and still oil leak.
Dit you solve the problem with a speedy slave?
see my treath " sportomatic 1969 oil leaks "
regards danny
Old 05-24-2018, 01:31 PM
OLD901 hasn't been on since 2013. Fishcop looks like he is still active.
I'm somewhat in the same boat - have a 77 sportomatic and will be rebuilding it, so probably will need some tlc!
I sent a PM to fishcop
Old 05-25-2018, 04:59 AM
