Wavey's Avatar
Sonofa%!&@%!
You know how the simplest things bite you some times? I was just cleaning my windshield, bumped the mirror and the freakin arm broke!
How the #@$& do I get the remaining part of the base off of the windshield? Checked Bentley's - nothing. Did a search - nothing. I'd really like to leave the glued-on disk in place and just get the black base off.
Looks like it's a snap-off thing, and I can get a pair of Channellocks on it. But do I rock it up-and-down, or sideways, or rotate it off, or? Car is an '88 Carrera.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 05-07-2008, 03:39 PM
subscribed... I have an 89 so I'm curious.
someone will know and send in shortly
Old 05-07-2008, 04:38 PM
gently tap from underneath until the stub comes off the pad.
206 637 4071
Old 05-07-2008, 04:41 PM
Wavey's Avatar
Thanks John! So it slides or snaps off, parallell to the windshield, correct? Owe you one - maybe I can take care of Arthur Obrien for you.
Old 05-07-2008, 04:54 PM
it sort of slides off but you have to tap it, parallel to the glass. i use a 3/8 extension with a bit of weight to it. light taps.
206 637 4071
Old 05-07-2008, 05:14 PM
rgrimm's Avatar
The base has a vertical "slot" that the mirror slides (tightly) into. So the trick is "parallel" to the glass. It goes in and out from the top.
If you're nervous, you'll need a new mirror anyway so wait until you get it...one look at the mirror and it will make perfect sense. I actually tightened the slot in the base a couple weeks back. Wish I had taken a pic...one look and you'd go "yeh, I get it"
Roger
1968 sand beige 911 Normale coupe #11830091
1984 metallic moss green with champagne interior 911 Carrera coupe
2012 silver with red interior Boxster
Old 05-07-2008, 05:28 PM
Wavey's Avatar
Thanks guys! Got it off very easily once I knew which direction to tap. I'm trying some structural epoxy that we use in the shop - just glued the joint and letting it heat-cure overnight, then some additional reinforcement around the joint tomorrow. Not much chance it will hold, but worth a try til I can get a new one.
Old 05-07-2008, 07:15 PM
Czar of C.R.A.P.
dfink's Avatar
After you have it epoxied then drill and tap with a flat head screw counter sunk into the base.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 05-07-2008, 08:25 PM
3.2 CAB's Avatar
Is that mirror arm some type of pot metal, or aluminum? Have you ever tried that low heat Aluma-weld product? I have 5lbs of rods, of the second generation Aluma-Weld. I still have not used it yet to see if it works.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 05-08-2008, 12:03 AM
Wavey's Avatar
dfink - great idea! I'll take a look at that.
3.2 CAB - it's definitely pot metal, very porous.
The point at which it broke is very small, about the size of a pencil eraser. It looks like a designed-in break off point, which I don't get since the base at the windshield is designed to break away.
Old 05-08-2008, 05:33 AM
Wavey's Avatar
The drill/tap/screw idea isn't workable - there's an additional tab to go through to get to the joint (sticking out in the photo). I guess you could do a larger hole through the tab for the screw head to pass through, but there wouldn't be much material left.
Well, the first round, gluing just at the break, seemed to hold very well, so I just added another layer to completely fill the gap around the joint. It's curing right now, will shape and paint later today. Heading out of town for an overnight trip, so I'll report back late tomorrow. A new mirror is only $72, so no big deal if it doesn't hold.
PS: JB Weld would have worked just as well, maybe better.
Old 05-08-2008, 07:41 AM
dreamer.
206 637 4071
Old 05-08-2008, 07:48 AM
Wavey's Avatar
HA! True enough. But I wouldn't have this car if I wasn't a dreamer
Old 05-08-2008, 08:08 AM
Wavey's Avatar
Hey John, ready to eat some crow? It worked beautifully. Installed it late yesterday, made an overnight trip of about 300 miles, and so far so good. I can hang on it until it feels like the windshield is going to crack. And I'm as surprised as you are.
Old 05-09-2008, 10:02 AM
