Tourque wrench setting
I stopped by the local tire store today. I am well known there. I the only person to locally own a Porsche 911 for about a 75 mile radius. We got to talking. They wanted to know about the tourque setting for the 06 Carerra RS. They wanted to know if they were really supposed to go to 406 Ft pounds? **** I don't know. My early car only gets set to 80lbs. Whats the deal? I told them I would find out. Any body want to help me explain. 406 The only other thing I could find even close was a F-40 or Enzo for 486 ftpds. This is for the one center type lug nut right?
Old 05-22-2008, 01:46 PM
Paul K's Avatar
Should be in the owners manual?
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 05-22-2008, 04:03 PM
Are you talking about the torque that the engine produces or the torque spec for the lug nuts? Confused.
Old 05-22-2008, 05:54 PM
Danny_Ocean's Avatar
LOL. Yeah...tell those pimply-faced kids the next time someone shows up with an '06 Porsche RS, they should torque the wheel nuts/lugs to 406 ft./lbs.
2006 Porsche 911 Turbo Specifications - Specs
engine Aluminum M96/70S Flat-6
position Rear Longitudinal
aspiration Borg Warner Variable Turbine Geometry (VTG) Twin Turbos
valvetrain DOHC, 4 Valves per Cyl
fuel feed Bosch Motronic DME 7.8 Fuel injection
displacement 3596 cc / 219.4 cu in
bore 100 mm / 3.94 in
stroke 76.4 mm / 3.01 in
compression 9.0:1
power 357.9 kw / 480 bhp @ 6000 rpm
hp per litre 133.48 bhp per litre
bhp/weight 302.84 bhp per weight
torque 620 nm / 457.3 ft lbs @ 1950 rpm
Furthermore, the car with one wheel "nut" is the Carrera GT..., and yes, the torque spec for the "nut" is 407 ft./lbs.
Old 05-22-2008, 08:01 PM
