Designer King
Please Comment on this Hole
![]() Is this hole the access hole for the screwdriver? Or, as I'm thinking, merely a drain hole, in which case I'll pry off the glass from the front?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 06-06-2008 at 07:17 AM.. |
Designer King
This photo should work
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Looks like the ring access hole in my 87 mirrors.
Chris 87 Carrera Coupe - Guards Red on black 00 Carrera Cab - White on Navy 05 Carrera S - Atlas Grey on gray 86 951 - India Red on black - Sold |
Definitely a drain hole.
The pry hole is oblong (L to R), and in the center, not toward the inside. I have both kinds. And actually the pry hole mirrors have 2 holes, a drain hole and the pry hole. |
1.367m later
+1 drain hole
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
Designer King
Thank you. It looks like it's some gentle prying for me.
I think that's the first time I've given expert advice on a hole.
No, wait, there was that one time... |
