tips for wiring harness removal 77 930
Need to remove the rear main harness for repair, is it a single piece to the fusebox or does it connect in spots and where would you disconnect if so? Thanks in advance
Old 06-08-2008, 08:19 PM
David's Avatar
If you're talking about the engine harness, the only difficult connections are on the alternator since you have to pull the alternator and the starter since it's somewhat buried.
Old 06-08-2008, 08:38 PM
Its the main harness that goes through the tunnel
Old 06-09-2008, 06:21 AM
