82 911 SC 68 Plymouth RR
martj's Avatar
Question Key hole lock set in door end
I found a key hole in the end of my door on the drivers side ? Alarm ? Help?
Old 09-16-2008, 02:18 AM
p911dad's Avatar
I once had an 82' 911 SC that had such a lock in the driver's door near the latch assembly. It was the alarm.
Old 09-16-2008, 02:38 AM
a.k.a. G-man
Geronimo '74's Avatar
Yes, it is most likely the factory alarm.
I have it on my 86, still works fine.
Old 09-16-2008, 02:41 AM
Registered knucklehead
83-911SC cab's Avatar
Like the others have stated it is the alarm arm/ disarm switch and uses a different key than your door/ ignition key.
1983 911 SC Cabriolet, 1989 944 S2
1969 Chevelle SS396 w/427 Vette motor, 1970 Buick GS455
2000 BMW 528i Touring, 2005 GMC Sierra
Old 09-16-2008, 06:34 AM
81turboporsche's Avatar
Send a message via AIM to 81turboporsche
i just pulled one out of my door,it was disconnected and i dont have the key that fits it,is there any way to get the key?porsche dealership maybe
1981 911sc Coupe "Valerie" Widebody
2001 Audi S4 Avant, "The Daily Booster!"
2001 Ducati 748 Biposto "The Torture Rack"
71 Chevrolet Corvette Roadster " The Moth Ball"
Old 11-03-2008, 08:31 AM
ruf-porsche's Avatar
The dealer will sell you a complete lock and key. The lock is electrical and not just a simple on off switch but has resistance. Removing or disconnecting the lock from the system will sometime cause the engine not to start. Better to leave the lock in place even if you don't have the key.
The German in their infinite wisdom probably didn't think about all the time people forget to remove the key after arming or disarming the alarm and end up breaking the key when they slam the door shut. German engineering, gotta luv it.
Old 11-03-2008, 10:19 AM
well the lock was in its respective spot but no wires were connected to it,prob the p.o had it removed
Old 11-03-2008, 10:30 AM
ToddM's Avatar
Send a message via AIM to ToddM Send a message via Yahoo to ToddM
Thats the factory alarm, when armed you have to open the door just enough to disarm it with the key or the alarm goes off.
Setting the alarm also activates fuel cutoff.
-Todd
'82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs.
Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete
Old 11-03-2008, 08:48 PM
