ZDDP in Shell Rotella T
Many of you will probably gain from this info:
I called Shell customer service, 800-231-6950, and spoke to a rep. (forgot to document his name, but very nice fellow) and I asked him how much zinc and phosphorous the new Rotella T 5w-40 synthetic contains. He said that it contains 1300 ppm vs. 1600 in the old formulation. Interestingly, 15w-40 contains 1200 ppm ZDDP. I don't think that loss of 300 ppm will make much difference. So, I am resting easier knowing that the Rotella syn. that I put in 2 months ago won't have to be replaced after all. |
The minimum is 1300 ppm right? If thats the case then I too will just buy the 5w-40 synthetic rotella.
That's a very good question. Does anyone know what the minimum is for our cars' engine?
Did you happen to ask about the non-synthetic oils?
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
Lots of reading here (Ultimate Motor Oil Thread or Why we hate CJ4/SM oils) but the answer is..... 1200 ppm minimum.
swepco
That being the case what is the ppm level for Swepco 306 20/50?
M-74 Last edited by AshEvan; 10-13-2008 at 10:00 PM.. |
I do not have the data available but based on the recommendations of Charles Navarro and Steve Weiner, it is (in the words of the Rolls Royce Brochure) Adequate.
Mobil 1 Extended Performance 15W-50
Boosted, higher viscosity, fully synthetic formula for today's longer oil change intervals. HT/HS applications. Racing and Flat tappet applications SM ZDDP 1200ppm I just put the last of my original formula M1 15w-50 in my 993, still have a couple of cases of 15w-50 EP which looks to be good according to M1s data sheets.
The high mileage Mobil one 10w-40 is not SM but SL. Does anyone know the zinc level? Walmart has the 5 qt. jugs for $26.
1987 Indian Red Carrera Targa |
Why not just run Brad Penn and be done with it!
Gary R. |
Grade A 100% Pure
Because every Autozone carries Shell Rotella oils and many of us would have to order Brad Penn and have it shipped to us, which in my book is pretty darn inconvenient for an oil change. Gary
‘88 911 Carrera Cabriolet ‘87 924S Cabriolet Racing And Performance C.R.A.P. Gruppe #20 |
Details details....
Gary R. |
I usually place the order Tuesday afternoon and the box is at my doorstep Thur or Friday in time for the weekend oil change. Saves my time by not having to take a trip to the auto parts store. Do you have any local distributors that carry Brad Penn?
John D. 82 911 SC Targa-Rosewood 2012 Golf TDI |
Gary R. |
Grade A 100% Pure
No, I’d have to drive two hours to up Portland (during the work week) to get it. Or order it from someplace back east which typically takes a week, or judging by how long it took to get the oil for my gearbox, several weeks.
….On the other hand, there’s an Autozone a mile from my house. Gary
garyR, you're running Brad Penn?
'83 SC |
The Rotella T 5-40 has the right ingredients, but several folks, including Steve Weiner, say it is too thin to run in a 911, unless it is winter and you are in a very cold locale. If never really understood why it matters if the second number is high enough (I know we wouldn't want to run a 5-30).
Designer King
Rotella T also comes in 15W 40. That's thicker when cold.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
