krd krd is offline
krd's Avatar
funky lights
this is a second post regarding this problem, just updated. first - my turn signals don't blink (hazards do blink though)only if headlights are turned on, otherwise they don't come on at all. second - when i step on the brakes my running lights turn on.
1988 porsche 911 "CE" cabriolet
Old 10-27-2008, 01:33 PM
krd krd is offline
krd's Avatar
help!!!!!anyone
Old 10-27-2008, 02:12 PM
crustychief's Avatar
I think you have a bad ground. That may explain the hazards blinking by using the headlight ground and your brake lights feeding through the parking lights. My guess would be the rear of the car.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 10-27-2008, 02:30 PM
BTW.. NOT a professional, just my WAG at it from my computer.
Old 10-27-2008, 02:31 PM
I had similar issues with my '76 912E. Check/bypass the ground wires in/near the headlight buckets. My car had bad grounds in this area and once cleaned up the problem went away.
Fran
Old 10-27-2008, 03:07 PM
