Info for spring projet
Hello,
I am planning to do my clutch this spring on my 911 3.2 1989. what else should I tell the mech. to change at the same time. thanks
_______________ Ducst4 1989 911 3.2 |
Recreational User
How about a new clutch cable and helper spring?
There is no clutch cable on an '89. There was a change to a hydraulic clutch in '87. There is an update to the shift fork on the transmission but I think it was standard by '89.
Chuck '96 993 C2 coupe '87 Carrera coupe - gone but not forgotten many lesser vehicles |
What clutch kit would you guys recommend?
Aren't there like 2 or 3 kits just from Sachs. Their might have been a slave cylinder update as well, tell him to check part #'s. |
Recreational User
Oh yeah, forgot about the hydraulic clutch after 86. In that case, how about a new master cylinder.
New throw-out bearing, surface flywheel, possible seal on transmission input shaft, new bearing for transmission input shaft in the rear of the crankshaft...
