kodioneill's Avatar
location of headlight washer relay
1982 sc
need to diagnose inop hwr
does anyone know where the headlight washer relay is located?
where does fuse # 19 get it's power from? haynes manual shows current track III 11 witch is also connected to seat belt relay.
where is the washer pump located?
haynes manual doe's not show any locations of relays.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 01-23-2009, 11:45 AM
kodioneill's Avatar
found the pump still looking for relay
found relay in parts diagram but does not show where it is attached
1982 chiffon 911sc
Old 01-23-2009, 12:12 PM
Registered knucklehead
83-911SC cab's Avatar
I believe the relay is right above the windshield washer pump mounted to the front sheet metal. I checked and the one on my car in that location has a part number on it of 928 618 11100. This number when entered Pelican parts look up comes back as headlamp washer relay 928, 968.
http://www.pelicanparts.com/cgi-bin/ksearch/pel_search.cgi?please_wait=N&forumid=&threadid=&command=DWsearch&description=928+618+11100&I1.x=10&I1.y=8&FILTER_928M=ON
I cross checked wires on mine to Bentley manual and colors appear to be identical.
Hope this helps
Gregg S.
1983 911 SC Cabriolet, 1989 944 S2
1969 Chevelle SS396 w/427 Vette motor, 1970 Buick GS455
2000 BMW 528i Touring, 2005 GMC Sierra
Old 01-23-2009, 02:01 PM
NathanR's Avatar
Send a message via Yahoo to NathanR
I can confirm what Gregg S indicated. It is screwed into the front bulkhead, in the trunk, very close to the wiper washer pump. I recently uncovered it during my H4 install, was perplexed as to why it would be installed on a car with no headlight washers. it must have been a part of all the factory wiring looms, I'm guessing.
Cheers,
Nathan
87 Carrera Coupe
Black on Black, H4 Headlights, Nurburgring Sticker
Old 01-23-2009, 04:34 PM
ruf-porsche's Avatar
Does anyone ever use the search feature or do you feel that you're the first one to ever encounter this problem?
Here's a similar thread on the relay.
http://forums.pelicanparts.com/showthread.php?t=451799
Old 01-23-2009, 07:09 PM
kodioneill's Avatar
ooops sorry sometime i go headlong in and forget.
i did not know the lights had to be on.
i own a 74 targa but the sc is new to me anyway thanks for the info.
1982 chiffon 911sc
Old 01-24-2009, 12:36 PM
