Benefits of a Flat fan ie 934, 917, etc
I was just wondering what, if any, were the benefits of having the cooling fan flat on the 934?
Current BMW Owner, Future Porsche Owner |
It's all about the look, nothing more, nothing less
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
EMT/TechRescue Instructor
Isn't the fan used for coolin'? ![]() Mommy told me I was her special lil' boy
David 1986 Iris blue 911 Cabriolet 2017 Ram 1500 Night edition 2025 BMW X-5 |
It creates more even cooling and more air(travels from the grill 90 degree into the fan, not a 180 degree turn from grill to fan)
John
997 C2S 2005 "Slate grey"(special order 1965color) 911 SC 1978 Silver/black 34.000 miles from new! 911 2.2 S 1971 Albert Blue/Black and 911 2.2 T 1971 Tangerine/Blood Orange/Black Sold: 911 2.4 S 1973 Viper Green/Kelly Green; 993 C4S 1996 Black/black; 993 C4 1994 Black/Black; 996 C4 2000 Black/Black; 996 Turbo 2003 Silver/Black |
Read some place years ago that the flat fan set up sucks 35 hp from the motor. Cool when you are making huge turbo power
Maybe someone here has the stats on what a standard fan takes to drive ?
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
AutoBahned
Here ya go, Dave...
from Ludvigson, EXCELLENCE WAS EXPECTED, 1st ed., Ch. 16 On the 1963 911, the cooling fan took only 4.7% of the 901's gross engine output - p. 402 -- a LOT less in other words too many gears & shafts with frictional losses in the horizontal fan I guess |
According to Mezger's 917 tech paper...
"The cooling blower is arranged horizontally above the engine. It has a diameter of 330 mrn (13 in) and supplies the cooling air for the engine at a rate of approximately 2400 l/s at the rated engine performance. The blower is driven via bevel gears at a ratio of 17: 19 of engine speed. As already mentioned, at maximum engine power the power input to the blower is 17 hp, i.e. 2.7 per cent of the engine performance. Of the entire cooling air volume 65 per cent is used to cool the cylinder heads and 35 per cent for the cylinders." He cites the 3 litre 8 cylinder race engine (908) as absorbing 14hp. |
AutoBahned
hmmm, somebody do a scatter plot of the data
Thats a 962 IMSA motor i believe.
In fact, its a lot more than about the look, as the factory did nothing if it didnt help their motors last longer for endurance racing. As John mentioned, and as we know from installing brake cooling ducts, air hates to travel around corners, esp for cooling purposes. Much more efficient to draw air across the engine vertically vs horizontally. Does look bad-ass cool tho ![]() For a mere $8500 or so (depending on the strength of the Rand) you can put one on your motor http://www.baileyedwardscars.co.za/FOR_SALE.HTML You then gotta get the ITBs and custom IC if turboing. Keep your eyes peeled for an install of this fan kit coming to a location near you
DZ12,935K3,934,2.8RSR Ducati 900ss/GhezziBrian STW dzugautomobili.com |
Silver '88 RoW Carrera Grey '06 A4 Avant |
Sultan of Sawzall
Hmmmm. flat-6 engines with top-mounted "flat" magnesium cooling fans?
Heresy, I tell you...HERESY! (no, not Klipsch) ![]()
Gruppe B #319 2 '86 911 Carrera coupes (red & white) '66 Corsa convertible 140/4(red) '66 Monza coupe 110/PG(white) '95 993 cabriolet (wife's) |
Ohhh... A 110 and a 140! Never seen a 110 with air - cool!
I always wondered what the HP loss was for the Corvair setup. Some of which is obviously mitigated by running the alternator off the same belt. We often threw our belt though at high RPM on our Corvair. Kept a spare all the time. Well, that and a fuel pump rebuild kit because that failed about every six months... angela
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
Were there non-air cooled Corvairs?
David 1972 911T/S MFI Survivor |
Friend of Warren
I think he was referring to the AC on the 110 hp Corvair.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Go Gators!
Oh man, that 140 brings back memories! A '66 Corsa, with all those factory gauges. The first motor I ever rebuilt and the joy of Unisyn-assisted carb tuning. Also, an early indoctrination to the belief that "all cars leak a little oil, somewhere...."
Timothy Stoops Air '62 356 B-‘86 911 Cab H2O '12 Cayenne |
The Corvair setup reduced the inertial mass by spinning just the mg fan. The alternator has a separate drive pulley (and drive ratio).
I don't think the 90 deg. drive belt arrangement has drive issues that can't be mitigated by modern technology. Sherwood |
R&D guy
Location: the border between the states of inebriation & confusion
horizontal fan - other apps
Interestingly, the advantages of using a similar horizontal fan and housing can be found in other products.
Either that, or this new Antec "Skeleton" PC enclosure was designed by a rabid Porsche racing car enthusiast. ![]() Seriously. This is a new product from a well-known maker of PC enclosures and power supplies. http://www.antec.com/Believe_it/product.php?id=NzA0 |
