Benefits of a Flat fan ie 934, 917, etc
I was just wondering what, if any, were the benefits of having the cooling fan flat on the 934?
Current BMW Owner, Future Porsche Owner
Old 03-11-2009, 12:44 PM
It's all about the look, nothing more, nothing less
Old 03-11-2009, 01:03 PM
Axeman's Avatar
Damn that looks hot!
Old 03-11-2009, 01:06 PM
safe's Avatar
Better, more even cooling. A must above 700hp
Magnus
Old 03-11-2009, 01:23 PM
EMT/TechRescue Instructor
86911cab's Avatar
Isn't the fan used for coolin'?
Mommy told me I was her special lil' boy
1986 Iris blue 911 Cabriolet
2017 Ram 1500 Night edition
2025 BMW X-5
Old 03-11-2009, 01:38 PM
It creates more even cooling and more air(travels from the grill 90 degree into the fan, not a 180 degree turn from grill to fan)
John
997 C2S 2005 "Slate grey"(special order 1965color)
911 SC 1978 Silver/black 34.000 miles from new!
911 2.2 S 1971 Albert Blue/Black and 911 2.2 T 1971 Tangerine/Blood Orange/Black
Sold: 911 2.4 S 1973 Viper Green/Kelly Green; 993 C4S 1996 Black/black; 993 C4 1994 Black/Black; 996 C4 2000 Black/Black; 996 Turbo 2003 Silver/Black
Old 03-11-2009, 01:49 PM
Read some place years ago that the flat fan set up sucks 35 hp from the motor. Cool when you are making huge turbo power
Maybe someone here has the stats on what a standard fan takes to drive ?
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 03-11-2009, 04:31 PM
AutoBahned
RWebb's Avatar
Here ya go, Dave...
from Ludvigson, EXCELLENCE WAS EXPECTED, 1st ed., Ch. 16
On the 1963 911, the cooling fan took only 4.7% of the 901's gross engine output - p. 402
-- a LOT less in other words
too many gears & shafts with frictional losses in the horizontal fan I guess
Old 03-11-2009, 05:01 PM
According to Mezger's 917 tech paper...
"The cooling blower is arranged horizontally above the
engine. It has a diameter of 330 mrn (13 in) and supplies
the cooling air for the engine at a rate of approximately
2400 l/s at the rated engine performance. The blower is
driven via bevel gears at a ratio of 17: 19 of engine speed.
As already mentioned, at maximum engine power the
power input to the blower is 17 hp, i.e. 2.7 per cent of the
engine performance. Of the entire cooling air volume
65 per cent is used to cool the cylinder heads and 35 per
cent for the cylinders."
He cites the 3 litre 8 cylinder race engine (908) as absorbing 14hp.
Old 03-11-2009, 05:02 PM
AutoBahned
RWebb's Avatar
hmmm, somebody do a scatter plot of the data
Old 03-11-2009, 05:12 PM
juicersr's Avatar
Thats a 962 IMSA motor i believe.
In fact, its a lot more than about the look, as the factory did nothing if it didnt help their motors last longer for endurance racing. As John mentioned, and as we know from installing brake cooling ducts, air hates to travel around corners, esp for cooling purposes. Much more efficient to draw air across the engine vertically vs horizontally. Does look bad-ass cool tho
For a mere $8500 or so (depending on the strength of the Rand) you can put one on your motor http://www.baileyedwardscars.co.za/FOR_SALE.HTML You then gotta get the ITBs and custom IC if turboing.
Keep your eyes peeled for an install of this fan kit coming to a location near you
DZ12,935K3,934,2.8RSR
Ducati 900ss/GhezziBrian STW
dzugautomobili.com
Old 03-12-2009, 08:07 AM
TheMentat's Avatar
I'd imagine that the horizontal fans in race applications are geared to push a lot more air at a given RPM, hence the seemingly high numbers...
Silver '88 RoW Carrera
Grey '06 A4 Avant
Old 03-12-2009, 09:04 AM
Sultan of Sawzall
rouxroux's Avatar
Hmmmm. flat-6 engines with top-mounted "flat" magnesium cooling fans?
Heresy, I tell you...HERESY! (no, not Klipsch)
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 03-12-2009, 09:07 AM
Laneco's Avatar
Ohhh... A 110 and a 140! Never seen a 110 with air - cool!
I always wondered what the HP loss was for the Corvair setup. Some of which is obviously mitigated by running the alternator off the same belt.
We often threw our belt though at high RPM on our Corvair. Kept a spare all the time. Well, that and a fuel pump rebuild kit because that failed about every six months...
angela
Hello
Old 03-12-2009, 09:16 AM
angela
Angela can identify various Covair motors - very, very impressive
Were there non-air cooled Corvairs?
1972 911T/S MFI Survivor
Old 03-12-2009, 09:53 AM
Friend of Warren
I think he was referring to the AC on the 110 hp Corvair.
Kurt V
Old 03-12-2009, 10:53 AM
The flat fan is for aerodynamic purposes to keep the motor (and car) as low profile as possible?
Old 03-12-2009, 10:56 AM
Go Gators!
s2per's Avatar
Oh man, that 140 brings back memories! A '66 Corsa, with all those factory gauges. The first motor I ever rebuilt and the joy of Unisyn-assisted carb tuning. Also, an early indoctrination to the belief that "all cars leak a little oil, somewhere...."
Timothy Stoops
Air '62 356 B-‘86 911 Cab
H2O '12 Cayenne
Old 03-12-2009, 11:07 AM
The Corvair setup reduced the inertial mass by spinning just the mg fan. The alternator has a separate drive pulley (and drive ratio).
I don't think the 90 deg. drive belt arrangement has drive issues that can't be mitigated by modern technology.
Sherwood
Old 03-12-2009, 12:14 PM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
horizontal fan - other apps
Interestingly, the advantages of using a similar horizontal fan and housing can be found in other products.
Either that, or this new Antec "Skeleton" PC enclosure was designed by a rabid Porsche racing car enthusiast.
Seriously. This is a new product from a well-known maker of PC enclosures and power supplies. http://www.antec.com/Believe_it/product.php?id=NzA0
Old 03-12-2009, 02:33 PM
