Underhood option code sticker
My car was repainted about 10 years ago by the PO.
The option code sticker that goes on the underside of the luggage trunk is missing. Can someone confirm, if the one in the Owners Manual is exactly the same size and has the same information as the missing trunk sticker? If it is the same,is it a viable option the photocopy it from the Owners Manual and attach it to the underside of the trunk? Thanks in advance. Cheers, Geoff.
1984 911 Carrera....... |
Can anyone tell me the dimensions of the hood sticker??
The one in my handbook is 3.5" x 2". If the hood sticker is a different size or has different information on it, then I will leave the hood without a sticker. I'm just trying to establish what the hood sticker is like. Cheers, Geoff.
1984 911 Carrera....... Last edited by Red Clubbie; 05-22-2009 at 05:39 PM.. |
Geoff in my ROW 89 Carrera the sticker is 3.5 inches by 3 inches in the handbook as well as on the underside of the hood. One problem though, by checking this out for you I noticed that all the numbers on the two stickers aren't the same which is a bit of a worry. I have recently obtained an ownership certificate from Porsche which agrees with the handbook dates etc but the main numbers on the handbook sticker don't match the sticker under the hood which matches the chassis number. The option codes do agree on both though.
Anyone out there have ant ideas on this?
Newcastle NSW Australia. 1989 ROW Carrera 3.2 Slate Grey. |
My underhood sticker (86 US Carrera) is just under 3.5" by 2 1/8". It contains similar info to the sticker in the manual, but in a different format/layout. Here are pictures of both...
Mark ![]()
hhmmmm looks like I have a problem that needs investigating
I was able to find a pic of a 1989 underbonnet sticker....
![]() It appears to be a different format from the owners manual. Cheers, Geoff.
Mark,
Thanks for posting the pics of both stickers, much appreciated. Cheers, Geoff.
![]() I can reproduce them I did several for 964, 993, 996 and 986 Boxster. Including maintenance booklet Duplicated No problem to do it for a 911 SC
SOLOPORSCHE ADMINISTRATOR Last edited by juankimalo; 01-21-2013 at 02:57 AM.. |
The ROW cars should have the last 5 digits of the VIN match between the VIL (Vehicle Information Label) and the actual VIN on either the door jamb plate sticker (depending on year) and the VIN tag on "A" pillar or windshield/dash area as well as the raised stamp VIN in the luggage compartment just above the spare tire. If the last 5 digits match you should be fine, if this sequence is different you should investigate further. Mike |
Cars and Cappuccino
Can you describe this recreation process in more detail?
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
I'm using a template.
I've working very hard in 2 different software programmes to do it. When someone ask for a sticker, I need all the data. If you don't have the maintenance record booklet sticker, there are some things that I need as VIN , color, interior, MY, type, engine, transmission and optionals. I send the sticker to the owner in an envelope.
SOLOPORSCHE ADMINISTRATOR |
Are you still making these stickers, can you message me. I just joined so the forum won't let me PM yet.. Thanks |
If he’s not making them, you can get these stickers (and many more) from CarBone in Poland.
https://www.carbone.pl/en/products/under-hood-and-warranty-paper-stickers-1981-1986-69 Mark
1979 911SC Targa |
Juan, are you making these sticker, I need a for me 930 1978
Titanium User
78 wouldn’t have had it
Buy some Titanium Lug Nuts! http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html ig: @ti_porsche_products |
