rebuilding front brake calibers?
How do you get the pistons to come out? they are disassembled down to halves and need to push pistons out? Do I have to reassemble them and use air or something to push them out. Any one done this before? Tell me what I have to do. I have the parts and they don't look to complicated.
First thing is to search on this topic, it has been posted many times with pictures, detailed explanations etc. I am not blowing off your question, just saying that someone else has already provided the info on this site.
The short answer though is you can pop them out with air or fluid, many variations on the same theme, pressure gets them out. PLEASE read up first as when these puppies finally let go they can be projectiles! Once you get the first one done, they are all a snap after that, it's just doing it for the first time. Here is a good start, from the Pelican Parts Technical How To Articles, but there are TONS more in the archives. I'll try a search later on if you don't get links directly..... http://www.pelicanparts.com/techarticles/911_caliper_rebuild/911_caliper_rebuild.htm -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... Last edited by cbeers; 02-12-2007 at 11:45 AM.. |
Diss Member
If you use air be careful because they will come out with great force. You want to pad them with something so they don't get dinged when they come out.
I prefer to use a set of extra heavy duty snap-ring pliers. They just grab the inside of the piston and you rotate them out.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Yes - read up on this. I fear you have already made a mistake, since you say you disassembled them into halves. Unnecessary, complicates things as you have found out, and requires something the rebuild kits don't have - new little seals to go between the halves.
I suppose you can blow air into the passage between the halves for one side, and block off the threaded line in hole for the other side. All you need for air is a rubber tipped nozzle, if even that. But with them apart you can't just plop a piece of wood in between the halves to limit the excursion and so on. You have created a small air mortar. Or use Wayne's version of internal pliers - that would be a good thing to have. Always something one can learn. Walt Fricke |
disband
walt points out your BIG mistake. you know, the breaking them in half. ouch!
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Automotive Monomaniac
It's a fun project, but you want to read up on it first. Breaking them apart may cause some misery.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order) |
Now in 993 land ...
Maybe searching for "calibers" instead of "calipers" did not help.
It's not a spelling bee here, but when searching, it is a good idea. ![]() The seal for the halfs is available, no problem. It's not like you killed your calipers. Just put them back together. When using air to push them out, restrict travel with a piece of wood, if it can not go further than 10 mm, it won't hit you in the head either. Rebuilding calipers is pretty easy, overall. George |
If you regret disassembling them into half you could always try to use them as exchange units for reconditioned items. Very often when you buy reconditioned calipers they ask for your old ones in exchange, and if they took your two halfs it might save you the hassel of sticking them back together again. I think reconditioned calipers aren't expensive.
I'm going to do my front calipers next week. I can't wait to fix an annoying dragging caliper I have.
Charles '84 911 3.2 |
reassembled them and made sure the rubber seals didn't fall out so I'm good.
Anyway...when I did mine I blew them out with the little air compressor I use to put air in my tires, you know, the type that plugs into the cigarette lighter. They come out with a vengence, so I c-clamped some pieces of wood to stop them (per recommendations). Piece of cake them to use your fingers to pull them out. I don't know, using pliers and such around pistons makes me nervous.
Rob Black 1983 911 SC Coupe |
Back in New England!
Erakad,
Great suggestion! I'll try your method to remove my pistons in the calipers in the next month or so. -Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
To clean the old calipers, I soaked them in a bucket of hot water and laundry detergent (yes, like TIDE). Soak for a couple hours, and then use an old toothbrush. Decades of grime floats away... and it doesn't hurt the gaskets.
Good idea - I'll give that ago when I do mine next week. Saves on buying brake cleaner stuff.
It's amazing how common household detergent work so well for cleaning and degreasing dirty bits. I used laundry powder for my heads, although I used Surf rather than Tide - I liked the pine fresh fragrance.
How do you tell if you have dragging calipers?
In addition, I used a hand-held infrared thermometer to check the temps of each caliper after driving for about ten minutes on an open stretch of road. The hanging caliper was noticably warmer than the others because it was dragging.
Here's one you can try:
http://forums.pelicanparts.com/showthread.php?threadid=270086 I didn't use a compressor, but prefer a regular pump as I would use on bike tires. The feel of the applied pressure is much better. The only problem is attaching the line to the brake fluid feed line opening. I just cut off the rubber hose from the pump and pushed that in the hole really hard. It's not that much work getting the pistons out and the whole rebuilding process was the first work I carried out on my 911. Good luck. - Michiel
'94 964 - Celebration 30 Jahre edition '06 997 - arctic silver with cocoa interior - sold '77 RoW 911 - black and still sexy - sold and I miss her '05 Audi A3 Sportback 1.9TDI (not a bad daily driver) - gone |
I just did this job and it is easier than you would think. I used all the "Pelican approved" hints: bike pump, c-clamp, baby food lid, etc. I used the bike pump method since I do not have a compressor and it worked perfect. I placed a hockey puck between the pistons and pumped air through the line and on one caliper both came out a hitch. Once they hit the puck I used a smaller piece of wood for till they popped. Drivers side was a little more sticky so c-locks were needed.
I used a plastic pencil to removet the inner seal and cleaned with alcohol, brake cleaner and wet sanded away grime and a few pock marks with 2000 grit. Once cleaned all went back in perfect. Oh, forgot to mention the home made 20 degree guide form the $1.00 Walmart protractor! Good luck!
$35 and a six pack to my name..... '88 Diamond Blue Carrera CE 3.4-SOLD
Mine came out using an air nozzle (very low pressure, it does't take much).
Rich
1976 911/S/SC/BASTARD Mid9 Member #12 |
old german, first porsche
Thank you all for the info. I have a sticky caliper on the passenger front and was going to replace them with rebuilt. I think I'll try to rebuild them myself first. Haven't done that in probably 25 years but I'm looking forward to the fun. It's been suggested to replace the lines with stainless steel. Any comments?
Thanks Karl in Gig Harbor, WA 88 Carrera Cabrio |
