Porsche Crest RE; Spring Plate Bushing Removal
Know this topic has been covered before but can't seem to find the thread or the tech article.
Have removed my spring plates from the car and want to know the trick on how to remove those old worn out rubber bushings????
Found the article on removing from the front suspension but not from the rear spring plate
Old 05-31-2009, 03:50 PM
abit off center
cgarr's Avatar
I heat up the inside of the spring plate and the bushing will peal right off, mostly.
______________________
Craig
G2Performance
Old 05-31-2009, 03:54 PM
Mr9146's Avatar
Get the torch.
Old 05-31-2009, 04:13 PM
the the is offline
the torch works, sometimes i've gotten lucky and had to only use a moderate amount of heat, other times I've had to heat them until they've practically burned/melted off.
Old 05-31-2009, 05:51 PM
ratpiper71T's Avatar
Here?
I think this is what you're looking for.
http://www.pelicanparts.com/techarticles/911_suspension_bushings/911_suspension_bushings.htm
Mama lock your daughters up that wild bunch is back in town!...And them little girls get frisky when they hear that race-car sound!
Old 06-01-2009, 06:03 AM
bushings
THANKS
Pretty much used your suggestion and got them off last night.
Old 06-02-2009, 03:54 AM
I have to change out my bushings on my 1973.5T, but I do not have a way of pulling them straight out as I would have to remove the lower rocker panel.
What is the secret to removing the torsion bar from the bushing plate? The car afterall is over 35 years old!
Bob
Old 06-02-2009, 04:25 AM
tharbert's Avatar
You should have a torsion bar removal plate under the rocker trim. Actually, you should be able to see the top of the plate sticking above the trim:
I believe the trim comes off with a few sheet metal screws?
Old 06-02-2009, 04:58 AM
