-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Wheel size questions (http://forums.pelicanparts.com/showthread.php?t=477417)
marcsalleras 05-31-2009 05:34 PM
I have a 1986 911 carrera non turbo with stock flares.... I'm wondering what max size tires I can go without having to weld on some steel flares, I have 205's on the front and 225's on the back right now and it looks like theres maybe between an inch to an inch and a half of space on the rears before i touch the fenders......any ideas on how big I can gow without adding on flares?
Oh Haha 05-31-2009 05:41 PM
255/17 is a popular size for the rear of SC/Carreras with standard flares.
265/45 will fit but that size is pretty slim in a street tire.
If you have stock 16 inch wheels the biggest issue is finding tires in a "fat" size that will work.
The tire diameter for our cars is right around 25"
here's mine with 245/45/16 with Sumitomo tires.I also have a .25 spacer installed.http://forums.pelicanparts.com/uploa...1243816870.jpg
efhughes3 05-31-2009 05:42 PM
If you'll do a search on "tire size" "largest tires", or similar term, you'll find more than you ever wanted to know.
Jack Olsen 05-31-2009 05:51 PM
245/275
Oh Haha 05-31-2009 05:51 PM
Here's a good one:
http://forums.pelicanparts.com/showthread.php?t=66476&highlight=largest+tire+size
Ed, don't you have a fairly wide tire on Ruby?
wildcat077 05-31-2009 05:52 PM
I just installed a set of 9 inch wheels with 245/45/16 tires on the rear and 225/50/16 tires on 7 inch wheels this weekend on my 89 Coupe with no issues... I will be lowering the car to "euro" specs as soon as i replace all four original shocks with new Bilsteins.
Right now i'm running a two finger gap between the top of the tires and the fender lip
front and rear as that is the lowest i could go for now without any rubbing...
Had to go for a few test drives and readjust the front height as anything lower than that would rub on the tires over bumps !
There is no concern whatsoever with the rear,the front is a little touchy with "tired" 20 year old shocks...
efhughes3 05-31-2009 06:11 PM
Originally Posted by Oh Haha (Post 4694294)
Here's a good one:
I do: 255/40/17 in the rear, 225/45's up front. But, I had to raise my car a bit in the rear to clear the LH side.
I suggested the search button, as there are alway's some asterisks and "buts" with this question on max sizing.
teamfee3 05-31-2009 06:16 PM
7&9x16s BFG GForce SS 205/55 & 245/50s
http://forums.pelicanparts.com/uploa...1243818968.jpg
16", not lowered, yet
wildcat077 05-31-2009 07:36 PM
245/45/16 on 9 inch and 225/50/16 on 7 inch,installed on Friday with a 2 finger gap on all four fenders,will be lowered as soon as i replace original shocks with Billsteins...http://forums.pelicanparts.com/uploa...1243823749.jpg
911st 05-31-2009 07:44 PM
Check out the new Kumho XS tires. The have a 265/45/16 that will work on a 9" rim. Is it suposed to be at the top of the heap on the near R type tires.
One of the best proven set ups seems to be 205/245's.
As Jack says, 275 17's is the widest rear and is what a lot of the PCA stock class guys are running. It should require rolling the fenders and might require moving the oil lines. Not an expert in this.
wildcat077 05-31-2009 07:49 PM
Rear view 89 Coupehttp://forums.pelicanparts.com/uploa...1243824526.jpg
marcsalleras 06-01-2009 04:54 PM
Looks damn good haha, so should I move the current rear 225's up front and buy 245's for the back?
wildcat077 06-01-2009 05:15 PM
It worked for me...
The problem is to find a tire company that makes the matching sizes for the front and back !
I found that TOYO with their Proxes T1R makes a wide variety of sizes and i'm glad i chose them because they are a lot smoother and quieter over road irregularities than the Michelin Pilots i had on previously.
I've still got the the 20 year old original shocks on the car... i just recently purchased it and will be replacing all four next weekend... but i have a two finger gap all around between the tires and fender and nothing rubs !
Will lower it slightly more after shock replacement !
