plymouthcolt's Avatar
Can't remove windshield due to antenna
I am replacing the rubber windshield seal and finally was able to get the windshield free. I can't remove it entirely due to the in glass antenna lead going into the dash.
Anyone know of an easy way to disconnect this lead?
Howard
2003 996tt
1997 911 Coupe Artic Silver (sold)
1988 Black 911 Coupe (gone but not forgetten)
Old 06-01-2009, 02:36 PM
the the is offline
It disconnects under the dashboard, passenger's side.
You get access to it through the front trunk area. If you get a flashlight, go on the passenger's side wall in the trunk, and look as far up towards the back of the car as you can (you'll be looking under the dash), you'll see where it plugs into a small, black box (roughly half the size of a pack of cigs). It is mounted on the pass side firewall in the trunk.
Old 06-01-2009, 02:41 PM
saintz's Avatar
"the" explains it just right
it isn't easy, be careful in there, lots of other things to disconnect by mistake
Newcastle NSW Australia.
1989 ROW Carrera 3.2 Slate Grey.
Old 06-01-2009, 03:10 PM
Thank you the
Howard
2003 996tt
Old 06-01-2009, 06:25 PM
the the is offline
you're welcome. be careful disconnecting it. if you break the antenna wiring, it's not a normal wire and I'm not sure you can easily repair it.
Old 06-01-2009, 06:37 PM
Immature Member
dentist90's Avatar
Related question: my (front) windshield has the defroster wires built in. Anyone know where the connection is for this before I begin to remove it?
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 06-01-2009, 08:54 PM
Throw it on the ground!
Here are some pictures of the plug you are looking for. IIRC is located behind the glove box. Idiot installer left my on top of the dash so I cut it off since I did not plan on using it.
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 06-02-2009, 05:38 AM
