77’ 911S |
here is mine again;-)
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
Jim 911 Mint Green "RSC" #mintgrun 911 Gentlemen's Rallye 85 Carrera GP White 2012 C63 AMG Mars Red |
PCA Member since 1988
Jim, Why different wheels on front and rear?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Back in the day, the race cars that wanted run wider wheels in the back found it easier/cheaper to find/use "8 spokes" (panasports/minilites etc) than Fuchs. So many period cars have the mismatch. I think it looks cool.
Fuchs didn’t come wider than 7” or 8”, can’t recall which, at the time of the first STs so Minilites were used
earliest RPO option 8x15 was for the '74 MY Carrera 2.7RS I suppose that some of the Minilight cars might have had 8s in back but the rules for the STs allowed +2 wheels which is 8 & 9 here's the earliest ST that I've seen w/ possibly 8 & 9 Fuchs, this is a factory pic of a '72ST
before they fit the ST flares in '71 the widest 911 wheels were7 ET23.3 front and 7ET49 w/ spacers in back see the post above
77’ 911S |
1984 3.2 Carrera
- Back to Fuchs (Maxilite) 16x8 (10,6mm) (225/50)+ 16x6 (36mm) (205/55). Missing center cups (71,6 mm :-( ![]()
![]() Sent from my iPhone using Tapatalk
1985 Carrera 3.2 • Prussian Blue Metallic |
Cars and Cappuccino
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
My 1986. Finally got my hands dirty and installed adjustable spring plates and with a lot of trial and error getting the stance where I want it.
1986 911 Coupe 1986 911 Targa |
83 911SC Cab
Chuck Miller '73S cpe #1099 - Matched # 2.7/9.5 RS spec rebuild '67 Malbiu 327 spt cpe - Matched # L-79 rebuild Creative Advisor/ Message Board Moderator - Early 911-S Registry R-Gruppe #88 |
| Tags |
| california sucks. |
