			 Author of "101 Projects"
				Neat Post of the day: Porsche 911 3-Valve Engine!
			A very kind fellow emailed me a few months ago asking me to put this up on the site.  I got very busy and sidetracked by a few important things (server failures, kid in hospital, etc - everything's fine now), and I'm just starting to catch up.  This stuff was / is too cool to let go, so here it is, more info to come:
	Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports  |
			Very cool Wayne, thanks for posting! Love the splayed intake .
	Aaron.   F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/  |
			 Almost Banned Once
			Awesome info... You can see someone's blood sweat and tears in those castings.
			The machining is a bit rough but these are prototypes so that's to be expected.
	- Peter  |
			The source may be a treasure trove of impressive information and photos. This should be carefully developed.
	Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975  |
			Fascinating!  There is some recent activity around new tech 4 valve air cooled heads in the Engine Rebuilding forum - this would fit right in.
	Chris https://dergarage.com ‘07 GT3, '80 SC Weissach (For SALE), '01 986S, '11 958S, '18 Stelvio, '18 Dursoduro 900  |
			Very interesting - maintaining a single exhaust valve to maintain air cooling. (no overheat between two exhaust seats)
	2.0L @ 9000rpm and 12.5:1 CR = .........  |
			thank you wayne!
			awesome !!
	1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race)  |
			 winter
			One of the things I love about this forum are the constant surprises that can be found here complimented by the great info that allows me to get my hands dirty and work on my car by myself.
	From Pesto's car with a very troubled history, to this engine, to the hint I got from someone to look really hard in the tangled mess of wiring under my dash for a wire that might need to be connected to my hazard switch and thus make my blinkers start 'a blinking, this forum has it all! Thanks to Wayne and everyone else who makes it such an interesting place to pass the time! ![]() --- Tom '75 targa  |
			dayumm!
			 UNDER CONSTRUCTION!
			see what happens i was looking for something else and now im sucked into another thread to take more time from the cars i need to attend to.
			![]() but man do i enjoy stuff like this keep it coming cheers ed
	Sometimes the first thing that comes to mind should be the last thing that you do!
 Ludwig Apfelbeck's thoughts as well as he made a 3 valve twin spark OHC head for the type 4 engine, which could probably be used on a 911 motor as well... www.apfelbeck.nl  |
			Thanks for pointing me to this thread Beetspeed
			![]() There are definitely similarities between these heads and Apfelbeck's Type IV heads: ![]() The dual camshaft on the above 911 heads are cool though! Nice stuff... one wonders if there aren't many more undiscovered gems and projects like these hidden in old sheds...
	'82 911 SC  |
				Thermal consideration to both 3V designs
			The difference in thermal pressure on the exhaust valve area is related to the 911 3V being DOHC and the Apfelbeck 3V being SOHC. The exhaust valve bulk together with casings for plugs and studs will become more disadvantageous for SOHC because DOHC setup allows both plugs positioned away from the exhaust bulk providing more open space for coolant closely along the very hot exhaust valve casing. Obviously 4V setup concentrates even more bulk that will be poorly accessible for cooling air especially in between the canals and seats. So alternatively twin exhaust canals should be situated well apart from each other often interfering with the existing studs. Now one realizes the need for water as coolant being more effective in cramped areas such as in between exhaust canals.
	So considering both enjoyable constructive jobs Apfelbeck did a fantastic job upgrading Beatles to almost Porsche level while the 911 3V upgrade design exercise only makes sense on Porsche level for maintaining air as coolant medium ……. saving weight but loosing surplus thermal absorption compared to water as coolant.  |
			 I would rather be driving
			Very cool.
			Looks like an M96 prototype.
	Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks  |
				Most interesting!
			Noticed that the intake guides are cut back to the port surface while the exhaust guide extends down into the exhaust port just above the exhaust valve head. Makes one wonder if the intake ports were flow tested and needed some help to match the flow characteristics of the larger exhaust port. Or, perhaps the larger head on the exhaust valve needed a longer guide for more support. Also, the intake and exhaust valves appear to be at a steeper angle in relation to each other with the spark plug hole located where the intake charge would get an optimum spark from both plugs. Some very good design work here!
	FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning  |
			 Call 911
			Thank you Wayne - very interesting!
	Dave Kirk My Porsche restoreth my soul.  |
			 Dave & Tonya
			Very cool but I have a question: does anyone retrofit roller cam followers to get around the lower Zinc and Phosphorus in the oil now? Detroit engine builders and hotrodders do it all the time both on OHC and pushrod engines...
			 Chain fence eating turbo
			Pants are tighter....
	Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel  |
