NOS911
911 3.2 Fuel Pump Upgrade Question
I am wanting to up grade my stock fuel pump in my 1985 911 with a high flow unit....
I have a stock fuel regulator.... I am sure there are a few Pelicans that have used 930 pumps before on turbo conversions. My question is if I use a front 930 direct replacement fuel pump, will the fuel regulator operate correctly and handle the extra flow back to the fuel tank. 911 3.2 Fuel Pump Upgrade Question
My Pelican Page |
Hi mate ,
I think , on my own , you'll need a new pressure regulator , that you'll be able to calibrate at the good value , in relation with the values of the new pump. If not , the stock regulator will continue to stay at the same pressure. Just my opinion , Cheers. Ced'
LIGHTER = FASTER !!! |
NOS911
I want to stay at my stock fuel pressure... I just want more flow so I can increase my Nitrous jet sizes.
I was thinking of replacing my stock unit with a unit used in the Turbo 930's.
My Pelican Page |
NOS911
Bump
Anyone ever install a 930 fuel pump on a 911? 1984 thru 1989 ?
I believe it is a Bosch part number 0 580 254 044
My Pelican Page |
